Question about Kenmore 72073 Top Freezer Refrigerator
Kenmore Coldspot Model 71182101
The freezer is cold. I do not have the ice maker hooked up. The refrigerator has stopped getting cold. I thought the the air circulation was blocked because the freezer had some ice crystals on the sides. I defrosted the entire unit for 12 hours and plugged it back in. You can hear it running but the refrigerator is still not cold 17 hours after plugging it back in. The freezer is working again. Help! L. Stoner Hagerstown Maryland
  • 1 more comment
  • Anonymous Mar 06, 2008
    The exact thng happened to my refrigerator. I thoughy it may be the fan motor?????
  • spybone Apr 18, 2008
    Exact same problem, anybody have any idea what to do?
  • jmaitia Aug 25, 2008
    I'm not sure which model Kenmore I have now (for only a few days), but it must be the most compact of the regular size models(maybe 14 cu ft.). It has a top freezer, and one crisper compartment in the refrigerator. My landlord replaced the full size Kenmore, because the refrigerator was not cold. The freezer worked fine. First he said that the freezer was too full. After throwing out more than half of the contents in my freezer, the refrigerator was still not cold. Now that I have a brand new Kenmore, the refrigerator again is not cold, and I have it on Max. What is going on? Does anyone know?
I have the same problem. The refrig and freezer are cold but not freezing and not cold enough. I have a friend tell me it probably is the relay. His did the same and that was the issue.
Posted on May 23, 2008
SOURCE:
Stopped cooling
My refrgerator a Kenmore, model 106-71182101, with ice maker stopped cooling and freezing.I vacuumed the condenser coils, and
fan in the rear bottom, along with any other debris. I unplugged the frig because the compressor was very HOT!.Question? Could the compressor have a Locked-Rotor? If so what can I do to loosen it.
Apr 08, 2013 | Kenmore 18.3 cu. ft. Top Freezer...
I have a kenmore coldspot fridge model # 106.73182302. It is only 7 years old and it is not keeping a cold enough tempature in either the freezer of fridge. The problem started with water leaking from...
my gsi 23 ice maker continues to flow water into the ice maker after the tray is full. It flows non-stop and floods the kitchen until I raise the arm that turns the unit off. I have no ice?
Sep 09, 2011 | Refrigerators
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore ice maker
yes you need to hook up a line froun the cold water supply of the house to the water valve that is located at the back of the ref to the water valve that is down at the botton right corner
follow the water line from the top going into the icemaker down to the bottom there is where the valve is located behind the back cover
Apr 11, 2008 | Refrigerators
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 72073 Top Freezer Refrigerator Logo
529 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
