ELECTRA SPLIT UNIT AIR CONDITIONER - NOT WORKING
I HAVE AN ELECTRA SPLIT UNIT AIR CONDITIONER FOR 10 YEARS NOW. I NEVER HAD ANY PROBLEMS UPTO NOW. SUDDENLY, ONE DAY, IT DOESN'T COOL ANY MORE AND THE GREEN LIGHT ON THE UNIT PANEL, BLINKS ALL THE TIME. IS IT DEAD? OR THERE IS A SOLUTION?
I HAVE REFILLED THE GAS, CHANGED THE CAPACITOR - BUT STILL THE FAN JUST STARTS THE FIRST TIME AND THEN THE FAN GOES OUT.
  • 1 more comment
  • parvthi123 Nov 16, 2009
    Hi Josh, thanks for your response. We have narrowed down the problem to the air conditioner outdoor unit fan. For the first time when the compressor starts, the fan fails to start even after replacing the capacitor. If we start the fan with our hand, the fan continues to run (at a very low speed) and once the compressor cuts - off as much heat is not dispersed, the fan fails to run again. Do you think the issue might be with the fan motor? Once again thanks for your response.
  • josh_ralling
    josh_ralling May 11, 2010
    You should check if the system has a call to run. On the outdoor unit there will be a feed in and interconnecting wires. Before checking anything else go to your outdoor unit and with the unit off try to move the fan to confirm it is not seized. if the fan moves freely then you'll need to confirm that the indoor unit is giving the outdoor unit power to run. Turn the system on and wait by the outdoor unit to check if the condenser fan runs. If the condenser fan starts and your compressor does not then your compressor is at fault. If the outdoor unit fails to run then you will need to start testing for further faults. Please enlighten me with more information when you have checked these basics.
  • 89 Answers
If the outdoor fan is the one you are talking about, it will not cool when it is not running. It sounds like the motor is over amping and going out on interan overload. You will have to change the motor for the fan outside on the condensing unit
Posted on Nov 17, 2009
Testimonial: "Hi - thanks for your comments. I am assuming the same and I am working on getting a replacement fan. Hopefully will be getting it by this weekend"
Hi, my timer led on the unit is flashing. the doesn't respond to the remote. it only switches on, when i press the button from the unit itself.
Posted on Jul 06, 2010
Air conditioner
it sounds like the reversing valve coil is faulty or the relay or contactor that supplier power to the coils is faulty and needs replacing
Jun 20, 2012 | Heating & Cooling
Split AC system not cooling.
P-7 Error Code means: DC Voltage Problem in the outdoor unit.
Bad PFC & IPM Circuit Boards.
The Pridiom Group
201-266-8234
Jul 26, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
Problem with compressor
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
May 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
Split unit a/c - works but no cool air only air. I was told the compressor broke and would need to be replaced at a huge cost.
The warranty usually reflects the worst case life expectancy. In other words if your warranty is for 5 years then they expect that if the unit was to be run consistently with regular to no maintenance It will only last 5 years.
These systems are very expensive. But that is not because of there longevity but for their unique applications. Manufacturers are not selling nearly as many Mini splits as they do regular split systems. So it is really just a supply and demand situation.
Jul 02, 2008 | Samsung AS18A6RB Air Conditioner
Air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Dec 10, 2007 | Heating & Cooling
Heating & Cooling Logo
1,071 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
