Question about Bosch Integra® 500 SHX55M05UC Built-in Dishwasher
What am I doing wrong? Our dishes don't come out clean at all with this. I love how quiet it is, but that is about all I like right now. I cleaned the filter and it hasn't helped. I cleaned the spray arms, I tried everything. We use the regular setting (about 2 hrs wash time for a full load). If I don't rinse the baby bottles, milk is still in them after washing so I know it is not doing a decent job.
    Top Expert:
  • Bosch Master
  • 48,226 Answers
Make sure that the heating element is working and use a good quality dish washer detergent ( not home brand s)
Posted on Aug 04, 2017
  • 8220 Answers
SOURCE: Top Dishes not coming clean
Clean ot replace circulation pump.
Clean or replce hoses
Posted on Jan 05, 2009
  • 27 Answers
SOURCE: Bosch dishwasher whining
if you listen to the appliance and the noise is louder on the rhs and low down this is probably the main wash motor they sometimes do whine if you can live with the noise leave it alone if not you basically have to take the whole applianmce apart for access to the motor costly repair would take a trained pro about 90 mins to replace the motor
if the noise is coming from the front of the appliance more to the lhs and is intermittant ie when it first starts up and then about half way through its likely to be the drain pump relitively easy to replace and you dont have to take the appliance to bits just go at from the front
good luck
Posted on Mar 13, 2009
  • 583 Answers
SOURCE: Lower spray arm does not spin on my bosch dishwasher
How to Check the Spray Arms Home > How To > Appliance > Dishwasher >Check 1x1.gif Caution: Please read our safety information before attempting any testing or repairs.
The pump/motor assembly pumps water up through the spray arms. The force of the water cause the arms to spin and spray the water and detergent mixture into the dish and glass racks. Some dishwashers have just one spray arm at the bottom in the tub, others have a second spray arm under or over the glass rack. Some dishwashers also have a spray tower that rises up out of the lower spray arm to concentrate an additional blast of water.
To access the bottom spray arm, remove the bottom dish rack. Reach in and spin the spray arms. They should spin freely. Lift up the spray arm from the end. There should some play in the arm allowing you to wobble it up and down. Inspect the seams of the arms for splits. If water sprays out of a seam, the dishes will not receive an adequate spray for proper cleansing and the force of the water directed at the door may cause leakage.
The lower spray arm may also have a spray tower. If it does, pull up the center part of it as far as it will extend and let it drop. It should lift and drop smoothly. You can also unscrew the tower by hand to inspect the interior for foreign objects that might clog it.
Remove the upper glass rack as necessary to access the upper spray arm. Repeat the steps above for the lower spray arm. The upper arm may not have as much wobble as the lower arm.
The water source for upper spray arm on some dishwashers may be through a tube which mates with the spray arm when the rack is pushed all the way back. Make sure that the rack is properly aligned with the water supply tube.
If necessary, the spray arm can be removed for cleaning or replacement. Unscrew the spray tower (if any) by hand and remove the bolt (if any) in the center of the spray arm. Otherwise lift and rock the spray arm until it comes off. Keep any washers in the same order as they are removed. To clean, soak it in warm water and rinse with a vigorous spray.
Posted on Mar 20, 2009
  • 63 Answers
SOURCE: dirty dishes
If you have a water softener, you should use about half the recommended amount of soap. Never use a wet or paste detergent. As mentioned before, this unit should be under warranty.
Gene, in AZ
Posted on May 24, 2009
  • 43 Answers
SOURCE: My Whirlpool quiet partner dishwasher seems to run
try a large cresent wrenck,or channel lock place towel over plastic nut,to protect from wrench damage.
Posted on Oct 10, 2009
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
Whirlpool dishwasher doesn't make the regular sound
The problem could be a clogged water line or intake valve. Check the lines and make certain they are open and flowing.
Feb 26, 2014 | Dryers
My GE quiet power 2 dishwasher isn't cleaning
its your water actually. go to and get the dishwasher filtration system. it filters the hard minerals that leave spots and film on dishes before they enter your dishwasher. you will love this product.
Apr 25, 2013 | Dishwashers
Hello ! We have a Whirlpool "Quiet Wash Plus" dishwasher that is approx 12yrs old. It has performed exceptional over this time, but notice recently it does not get the dishes as clean as before....
Is the water level ok? Check your water temp into the tub. It needs to be a minimum 120 degrees. Check for plugged spray arms. Do they turn freely? Does dishwasher drain completely?
Sep 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Our Maytag quiet series 200 does not clean or rinse dishes properly. It leaves film all over cups and dishes. Water also seems not to be draining out. It is 6 years old
It is not the dishwasher. The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to to find out more info.
Sep 07, 2009 | Maytag Dishwashers
Whirpool dishwasher gold quiet partner 3 is leaving a heavy film and waste on dishes is there a filter to be cleaned?
Jul 09, 2009 | Whirlpool Dishwashers
Dishes not getting clean
the problem is hard water. there is a new product out at that filters the water going into your dishwasher leaving your dishes crystal clean with every load. it is very affordable and works amazing. it even has a money back guarantee. you will love this product.
Mar 23, 2009 | Dishwashers
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it:
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosch Integra® 500 SHX55M05UC Built-in Dishwasher Logo
56 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
