Question about Brother 1034D Mechanical Sewing Machine
My serger i 'm having problems threading my serger
  • marty1234 Jun 25, 2008
    can not thread the left side bottom threaded from top ok
  • ibtwitty Nov 26, 2008
    I just got my brothers sergers machine.. even looking over and over at the cd I can't thread the lower threads.. this is my first serger.. were you able to solve your problem ?
    thanks, ibtwitty@cox.net
  • 397 Answers
What part of threading....you should have a layout on the machine itselft,,,,,
Posted on Jan 20, 2008
Why does lower looper keep breaking
probably need a adjustment, you may have to have the looper checked
May 26, 2016 | Sewing Machines
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
SERGER HAS BEEN RETHREADED AND HAS A NEW NEEDLE BUT WILL ONLY SERGE FOR ABOUT 1.5 " and THE THREAD BREAKS AND LOWER LOOPER COMES UNTHREADED.
7. Is the thread feeding off the cone/spool freely?
Aug 21, 2013 | Singer 14SH654
Can serger for about 3 inches on my brother 1354d serger and then thread breaks
Jan 01, 2013 | Sewing Machines
How to thread a serger model 934d made from brother it has 4 thread to do
You can look at youtube.com and see various sergers being threaded, also Brother at www.brother-usa.com, and www.singerco.com is quite helpful for threading a serger. All sergers pretty much thread the same way, remember always thread the 2nd from the right first. You can download your manual for free at the Brother site and enlarge the diagrams. Just take your time, it took me almost an hour to finally get it , now I can thread any machine without any problems. At first, I was very intimidated, but you will get it, really.
Mar 20, 2011 | Sewing Machines
My serger will only sew a few inches, then the thread on the lower looper breaks. I have checked threading, rethreaded many times.
Been there, done that. Old serger almost went out the window more than once.
Raise the thread antenna and loopers to their highest positions.
Set the tensions to zero. If your serger has auto-tension, raise the presser foot as this also opens the tensions.
Begin threading from the right as indicated in your manual or on the door of the serger.
If this continues, the serger may need to be serviced as the timing could be the problem.
Ask before leaving the serger as the service cost usually starts around $100.
I finally gave in and bought a Babylock with instant jet-air threading.
Apr 01, 2010 | White Sewing Speedylock 1600 Mechanical...
Lower looper problems
Some sergers require they be threaded in a particular order. If not, they do not "knit" the threads.
Raise the thread antenna to it's highest position.
Open the tensions (set at zero). If the tension settings are automatic, raise the presser foot to open the tension settings.
Turn the handwheel so the loopers are at their highest position. There may be a mark on the side of the serger to match up with a mark on the hand wheel for this.
Open the front of the serger and the threading guide should be printed on the inside of the serger door, or on the serger.
Start at the right and note which looper is threaded first and then the needles.
You can find more information and manuals at the Singer Co website.
Mar 24, 2010 | Singer 14SH654
Problems With the Tension serger kenmore
Open the tensions (set at zero) and have the presser foot up when threading.
Make sure the antenna if fully extended.
Turn the handwheel so the upper looper is at it's highest position.
Thread, beginning at the right thread cone unless the manual indicates differently.
After threading, set the tensions back to the recommended setting.
If this does not help, please provide more details.
Mar 10, 2010 | Singer Tiny Serger TS380
Good diagram showing how to thread a 4 thread Juki 644d serger we do not have a manual machine is not clear
You can download a free threading guide here - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_644_Threading_Diagram.htm
The same site also sells manuals.
Threading Tips:
Have the thread antenna at it's highest position.
Have the presser foot up while threading.
When you thread a serger for the first time, or if you are having a threading problem, use a different color thread for each guide. This can quickly indicate where the problem lies.
Once the stitch is satisfactory, change to the color you prefer - but this way is the easiest - cut the thread near the thread cone and tie off with the new thread. With the tensions at zero, slowing run the serger until the new thread appears. You will need to stop as the knots approach the needles and thread them by hand.
Do the tie-off before running out of thread and this will save a lot of time and stress.
Mar 02, 2010 | Juki MO-644D Mechanical Sewing Machine
Open Questions:
See all Brother 1034D Mechanical Sewing Machine Questions
Brother 1034D Mechanical Sewing Machine Logo
116 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
