Question about Amana ALG443RAW Gas Dryer
Amana dryer makes rumbling noise when the drum turns
  • Amana Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fsdjds
Posted on Sep 29, 2010
4 Suggested Answers
SOURCE: dryer makes rumbling sound when starting
If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
Posted on Jan 16, 2011
  • 5 Answers
SOURCE: amana dryer drum.
It could be a broken belt, an obstruction of teh fan or one of many things. Heres the catch, it isnt working so how in the world could you make things worse???
Take it apart and get in there to see what the problem is.
Posted on Oct 11, 2008
  • 11 Answers
SOURCE: maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Posted on Jan 18, 2010
Rumbling grinding
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Feb 17, 2015 | Dryers
Why is my divinci 6030 receiver making loud rumble noise when I push the power on in the back of unit. I have nothing hooked up to it.
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Dec 17, 2014 | Dryers
Bosch WTA 3510 uc/13 FD 8203 compact dryer is very loud. Motor is okay. Just changed the main pully. Belts are okay. Still is a loud rumble when operating. Any ideas? Rear bearing appears to be ok
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Oct 09, 2014 | Dryers
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Drum Bearing
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
Noisy
Most dryer drums have 3 guide rollers at the back of the drum. Over time they wear out and the dryer "rumbles" Sometimes pretty loudly.
Without make and model I can't suggest part number or exploded view.
Check the rollers You'll probably find one is worn out.
Jan 31, 2011 | Amana Dryers
Making noise .dhudam..dhudam...while working and drying clothes ..heating is fine
The thumping / rumbling your hearing is caused by a flat spot on one or both of the drum rollers. Item 13 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=22262&diagram_id=28335526#d28335526
You should change both rollers at the same time.
Also the 5 rib drum belt this link:
http://www.appliancepartspros.com/part_details.aspx?part_id=4049271
Make sure to inspect the idler pulley Item 19 this link BEFORE you order parts:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=22262&diagram_id=28335525#d28335525
Dec 03, 2010 | Amana ALG443RAW Gas Dryer
Drum vibrates unit and makes a rumbling noise
sounds like the blower wheel is bad.the blower wheel is behind the duct that the lint filter slides into,when the wheel goes it makes a rumbling sound,also you could have worn glides that the drum rides on or a bad roller,you need to get in there and look but i'm sure it's worth repairing
Mar 29, 2010 | Amana DLE330RAW Electric Dryer
Maytag dryer makes rumbling noise when drum starts and again when
Jan 17, 2010 | Maytag Dryers
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Amana ALG443RAW Gas Dryer Logo
400 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
