Question about Toro Lawn Mower With Toro Power Tools
Totr model #20479 GTS 5 motor, when you push prime
Toro mower model #20479 GTS 5 motor, when you push prime button 3X the mower starts and runs for 2-3 secs and quits. It has acted like it wants to stall while running perodically.
  • 486 Answers
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 16, 2009
I need a carb for toro gts5 model20462
Posted on Nov 27, 2009
Why won't my toro 6.5 gts start after taking blade offand replaceing it?
From flipping the mower on it's side the top of the cylinder gets slightly flooded with crankcase oil. A good priming and a few extra pulls on the starter cord is usually necessary after this type of maintenance. You'll see a few extra puff of oil smoke upon starting. This burns off in less than a minute.
Jul 15, 2014 | Toro Lawn Mower With Toro Power Tools
Toro super recycler
Push primer bulb at least 3 times. Pull starter rope until it starts. Ensure safety lever is engaged on handle.
Aug 02, 2013 | Garden
My mower starts when primed but immediatly stalls after. It is a GTS...hard to tell.
Most commonly, the main jet in the carburetor is varnish/debris plugged, or moisture/debris in the float bowl.
Nov 08, 2009 | Toro Lawn Mower With Toro Power Tools
Engine starts when primed but stops in seconds. When you push the primer button five times and then pull the rope, the engine starts, but then kills. It's a 6.5 hp on a Toro Recycling GTS mower. I ran it...
it sounds like you have contaminants in the fuel and have clogged the fuel filter or carburetor, try changing fuel filter if there is one and back flush the fuel lines with carb cleaner spray and clean out fuel tank and clean with brake cleaner refill with fresh fuel.
Aug 22, 2009 | Briggs & Stratton Garden
No gas to carb on toro gts
Carb needs to be cleaned/repaired. Without knowing model number of the engine, that's all the info I can give you.
Jun 20, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
6 yr old mower starts, won't run
sounds like a plugged high speed jet in carb - you can attempt to prime again , push at least 7-8 times - once it fires continue to push primer to keep running - it may clear out the carb if this doesnt work the carb will need to be removed and cleaned
Sep 27, 2008 | Garden
Toro Lawn Mower With Toro Power Tools Logo
892 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
