Question about LG Dishwashers
I have an LG dishwasher model 6810ST that comes up
I have an LG dishwasher model LDF6810ST that comes up with an LE error code. How do I correct this problem or fix it?
    President:
  • 1,865 Answers
LE means ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
You'll have to disassemble the unit and make sure nothing is stuck in the pump or locking the blade.
Otherwise you may have a loose wiring connector
Posted on Nov 16, 2009
Le error code
LE is "Leak Error" there is a sensor in the motor compartment that detects moisture. this code is activated when a leak is detected in the motor compartment. you will need lg to come repair it as it is a notoriously difficult thing to fix permanently.
Sep 26, 2013 | LG LDF6810ST Stainless Steel Built-in...
LE error code, bell ringing
Not an expert, but we paid $60 for the repair man to come out and just run his hand along the touch pad on the door. It stopped the error code and the bell ringing noise! I wish they would have mentioned that over the phone and I could have saved $60!
Nov 10, 2010 | LG LDF6810ST Stainless Steel Built-in...
Our dishwasher shows an LE error code when started. What is wrong.?
Le error is a motor error. either there is something lodged in the pump holding the blades or the motor itself needs to be replaced
Jun 22, 2010 | LG LDF6810ST Stainless Steel Built-in...
I have an LE error code
yes it can mean serveral things. Please check this SITE this is the service manual for your dishwasher. You can get parts at www.sears.com
just find your model. Service manual should help you a lot
Jan 12, 2010 | LG LDF6810ST Stainless Steel Built-in...
I'm getting a code "LE".
LE IS A LOCKED MOTOR CODE CHECK FOR OBJECTS IN PUMP BUT THE HAD THAT PROBLEM IS THE PAST
Sep 26, 2009 | LG LDF6810ST Stainless Steel Built-in...
LE error code
No recalls at this point. the repair man is correct. the circulation motor is damaged.
You should know that, this model has many issues that we deal with on this site that concern this (LE) trouble code. The circulation motors are not reliable in this model.
Jun 21, 2009 | LG LDF6810 Built-in Dishwasher
LG 6810ST Dishwasher- OE Error Code
SInce the drain hose is not plugged or kinked, the next step if to remove the filter that is beneath the lower rack done in the sump area. Remove approximately 10 phillips screws.
Inspect for debris in the mesh filter and underneath it, especially the drain outlet.
Reassemble and retest with a quick cycle.
If problems persist, suspect a failing pump motor. Schedule professional repair is recommended.
Mar 29, 2009 | LG LDF6810ST Stainless Steel Built-in...
Im getting error code "LE" on my lg dishwasher
While LE is the LG error code for "Motor Error": The Motor is working abnormally, it does not always mean that the motor itself has failed.
As you replaced the pump motor, are you certain that the Impeller of Washing Pump is turning freely? Next, is the Blade spinning freely?
If everything above is obviously not locked, the next item is the controller board. (PCB)
Hope that helps. Please report back with your findings! Good Luck.
Mar 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG dishwasher
L2 error code is the same as an LE error code.  You have a problem with the sump motor assembly and needs to be addressed by a qualified LG technician.
Apr 08, 2008 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
287 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
