Question about Agri-Fab AgriFab Soft Top MowNVac
How do you remove the impellar? - Agri-Fab AgriFab Soft Top MowNVac
  • 486 Answers
Remove the fastening hardware and 'set screws' that are holding the impellor to the crankshaft. Also remember that the crankshaft & impellor are 'keyed' to each other, they cannot rotate seperate of each other.
When you remove the bolt in the end of the empellor, you may notice threads on the inside of the end that are larger than the bolt you removed. Those threads are for a larger bolt that is used to 'push' the empellor off of the crankshaft.
Posted on Nov 16, 2009
Why is the motor roaring ? is it rubing on housing or a bearing ?
It may not be you motor, but the sound of some item caught in the impellar, which is the part that causes suction. It is usually located in the upper housing, and can be accessed fairly easily. Unscrew any visible screws,(usually phillips type) and carefully lift housing off. This should expose the impellar. If debris is present, remove it.
But also check for possibly broken fins on the impellar itself. Sometimes items like coins, or nails etc, will get picked up accidentally, then spin around in the impellar housing, only to break a fin or two trying to move on. If this has happened, replace the impellar.
Dec 22, 2015 | Hoover UH70105 WindTunnel TSeries Bagless...
Trying to fix the impeller
Take the unit to a mechanic with an air wrench or buy an electric impact wrench.
Gary @ Fix Ya
Dec 08, 2012 | Garden
How do I remove impeller from motor? Is there bolt or does it screw off? It appears head of bolt is sheared off.
The impellar spins off counterclockwise on most pumps. The hard parts are holding the motor shaft from rotating and finding a way to grip the impellar.
Gary
Jul 24, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
I am trying to remove a Centurion B849 from the impeller. I removed the 4 bolts. I come to find out that the shaft is threaded; so in order to rotate the motor, how do I remove the electrical wires on the...
I'm not sure I understand your question.
To get the impellar off of the shaft, leave the motor bolts on.
Open the back end of the motor, there should be a slot in the motor shaft. Use a screwdriver to hold the shaft from rotating and grab the impellar and rotate it counterclockwise to unscrew it.
It sounds easy, but the impellar is probably somewhat corroded on.
Gary
Jun 26, 2011 | AO Smith A O Smith Motors Centurion 1.5hp...
I have a US!1102 AO Smith 1HP Pool Pump Motor. I was told to hold one end of the motor shaft and turn the Impeller clockwise to remove the impeller, I was told NOT to remove the nut at the center of the...
I have never taken this pump apart.
If I were in your position and I could move the impellar 1/8 turn, the next thing that I would do is carefully loosen the nut on the end of the shaft being careful that nothing else disassembles. Once this nut is loose say 2 turns, try the impellar again watching what is moving. It seems that the nut may have to be removed.
Also, I'm not sure which way the nut of the impellar rotates to remove, but you seem to have that under control since you have it moving already.
Gary
Feb 20, 2011 | A O Smith Motors A O Smith 1hp 115/230v Ur...
The pull out hose does not have succion
I assume the machine is operational, just does not have any suction. If this is the case, then it is probably plugged with something. Remove the hose, if you can and see if there is an obstruction. If nothing is found, then the impellar may be broken. Does the machine make the normal sound as it does when you get a large object stuck on the end of the hose? That is the sound that the impellar is working, the motor races up, and then the noise subsides back to normal when you remove the object. If that is what your machine is doing, you have a plug somewhere. If the sound is just the sound of a high pitched motor and does not make the sound it does when plugged, then the impellar shaft is probably broken. A vacuum is a pump and the impellar is the same thing that makes a boat motor move a boat. The impellar on the vacuum is enclosed and pulls air in (suction side of the pump) from the end of the hose and blows it out (discharge side of the pump) into the receiver where you collect dirt and debris. So those are your two possible solutions. If you are the repairman (or woman) then you can go on line and find repair manuals for your vacuum free. Just google: repair manual for your brand machine. If not and the machine didnt cost much and you dont have a plug, then you will probably be ahead to go get another one. Most repairmen want at least $100 just to get started plus parts. Hope this helps you.
Feb 03, 2011 | Dyson DC18 Allergy Bagless Upright Vacuum
My Pentair WF-26 1.5 HP just started emitting a loud "whine" detectable above the regular pump noise. Looking through the window into the debris basket the water also looks more frothy than...
The loud "whine" you hear, does it sound like its a metal kind of "whine"? There are a couple of things it could be. Your impellar may have debris caught in it and to properly check and clean the impellar you will need to open up the pump and remove the diffuser and check/clean as needed. You can sometimes remove the basket and try to feel your way with a couple of fingers to the impellar but your only able to reach 10% of it. Whisperflo is an outstanding pump but very notorious for debris getting stuck in the impellar and the impellar breaking easily because it is plastic. If you have ran the pump without prime/no circulation you can easily have caused heat damage to the impellar. The other thing to check is the motor. Although it is only 2 1/2 years old the motor still could be going out. The bearings are the top noise makers when a motor is going bad. You will still have normal suction/circulation it will just be really loud when the motor runs each day.
I hope this helped. Please don't hesitate to submit any further questions you may have. I would be glad to help.
Dec 07, 2010 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
I have a Maytag Mod MDB8750AWS. I want to know how to get to the internal food disposer so I can clean it? Diagram would be helpfull, there is nothing in my owners manual about this!
Your problem is probably in the filter plate. Remove spray arm, filter cover, impellar housing and impellar.Them you can remove the filter plate. You can see a break down at www.searspartsdirect.com.
Mar 03, 2010 | Dishwashers
Replaceing the wet end seal on my hot tub
disconnect power take pump out remove front plate take back cover off motor use 7/16 wrench to hold shaft unless it has a place for a flat head screw driver at the back of the motor while holding shaft unscrew impellar counter clockwise take shaft seal off impellar make sure rubber gromet comes off with seal take back seal plate off motor by unscrewing bolts thru back of motor should be 4 knock out ceramic ring replace ceramic ring with rubber side toward plate reinstal back plate install seal on impeller with with flat side with rubber gromet toward back of impellar. screw impeller back on holding shaft if the shaft is rusty and pitted clean off with sand paper b4 reinstalling impellar lube up oring around front plate screw back tight and reinstal pump.
Sep 18, 2009 | Jacuzzi Impeller, L - 3/4 H.P
Replace impellor in yamaha 2 cylinder 40hp outboard motor
take all bolts out on foot were the two mate drop lower unit down pull impellar cover will be plastic some what roun with a short molded inlet on top when u remove impellar be sure not to lose the key way and when u put the cap on the impellar be sure to rotate it so blades will ben\d in place make sure u dont pintch them when u bolt the cover down MAKE SURE WHEN YOU PUT THE FOOT BACK ON TAT YOU LINE UP THE IMPELLAR INLET WITH THE ONE COMMING DOWN FROM THE ENGINE LINE UP YOUR SHIFTER LINKAGE (TOWARD THE TRANSOM IS WERE IT IS LOCATED bolt it up test with a hose should be good
May 12, 2009 | Boating
Agri-Fab AgriFab Soft Top MowNVac Logo
115 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
