Question about Toshiba MD20Q42 20" TV/DVD Combo
I am having a problem shutting off the subtitles on my Toshiba Model MD20Q42 TV. I've tried pressing the subtitles button but it doesn't do anything.
  • 34 Answers
Easy go to menu click on cc1 and you might be able to turn it off
good luck
Posted on Nov 16, 2009
Can i add an external speaker to my toshiba md20q42
If there is audio out jacks at its back panel. you can connect it with any amplifier, to get the sound amplified.
Sep 25, 2013 | Toshiba MD20Q42 20" TV/DVD Combo
More detail --- Toshiba md20q42 tv/dvd combo not powering on, initially when it happened i Hit power button and lite came on and blinks for about 3 seconds then turns off--- now when i push power button...
Hi
It is probably a power supply problem associated with standby circuit. If this circuit is bad the set hardly comes on and fails. This is a task for a technician to trace the fault through the whole power supply.
Sully
Sep 22, 2013 | Toshiba MD20Q42 20" TV/DVD Combo
How do I turn on the closed captioning on my Toshiba SD 5000 DVD player
What happens when you press the "Subtitle" button on the DVD remote control several times after you insert a subtitle-enabled DVD?
If you don't have the manual handy for your DVD player, I've added a link for the Toshiba SD-5000KU. The Subtitle button is described on page 13, but the description only tells how to turn subtitles on. However if the programming is typical, pressing the button repeatedly cycles through a series of language options with "Off" at the beginning or end of the list. Otherwise, it may be programmed to enter a subtitle menu that you navigate with the direction arrows (page 14).
Toshiba SD 5000KU Owner Manual
Jul 03, 2017 | Toshiba SD-5000
I have a sony bravi xbr ;the picture is sooo big i can't read the subtitles . i tried ti fix it ( from the instruction manual ) but nothing work . thank you !
Hi: Check you screens format button to change screen sizes, this button may also be labeled Aspect. Seems you are in ZOOM Mode, these buttons can also be found on cable boxes remote as well try pushing them to see if screen size change. If this does'nt help then do this with the TV in off posistion. Press the Display key on your remote, Then the Five key, then the Vol up key, then press power key. This will turn set on in service mode, you will see service options do not do anything but press the number 8 on remote and hit enter. This will rest tv to factory settings. All video setups and parameters you have set in user menu will result back to factory and will need to be redone. TV should shut down on its own and come back on on channel 3.
Dec 10, 2011 | Sony BRAVIA KDL-52XBR3 Television
I formated my toshiba l635.after downloading all the drivers from the internet to get back all the original toshiba programs.my computer doesn't respond to the fn button.when i press the fn...
From what you've mentioned, you have to install a TOSHIBA Hot-key utility that corresponds to the function or other utilities for specific tools. if you have the user manual of your machine it might help.
You can find them on Link, model is L635-S3025, this utilities will work on most L635 regardless of what model. After installing each utility try to press the function key try if it works, until all keys are working. not all utilities are key based some utilities work for protection or notification.
Hopefully this information helps and may you fix the problem.
Thank you for using FixYa.
Jul 29, 2011 | Computers & Internet
I am having trouble removing the subtitle feature from my Toshiba AV500Utv. I followed the owners manual and it if not help. If any advice could be offer concerning how to disable the subtitle setting or...
Looking for the CC button on the remote to close Close Captioning.Finding the button CC on the remote press it couple times for CC1,2,3 to all off,should have no more Close Captioning.Tries tv unplug,replug it back like 24 hrs later for to earase all the save data for the tv Tuner signal board.
Feb 05, 2011 | Toshiba 37AV500U 37 in. LCD TV
Hi I have a Toshiba CT-90326 Television. How do I disable the Audio Description on it? Thank you
Hello Clare,
CT-90326 is actually the model number of the remote control rather than the TV. It doesn't really matter as the correct button on the remote is more relevant than the actual TV.
The Audio description is a feature of the closed-caption/subtitle settings on your TV. You should be able to switch off the audio description by pressing the "SUBTITLE" button on the top row of the remote control. Each time you press this button it will cycle between ON and OFF.
If this doesn't work, it's probably because you are using a cable/satellite/digital receiver. If this is the case, look for a button on your cable/satellite/digital receiver remote control marked "CC" "CCD", "SUBTITLE".
Please try the above and then reply to me from within this page. Please state the model number of the TV and any cable/satellite/digital receiver you are using if/when replying.
Thanks,
BElectric
Jan 28, 2011 | Toshiba Televison & Video
My toshiba dvd/tv combo power button just stopped working. Where do I find the fuse box?
Make sure it is unplugged then follow the power cord to the board it is right in front of where the power cord attaches to the board.
Sep 04, 2009 | Toshiba MD20Q42 20" TV/DVD Combo
I have a Toshiba TV/DVD combo model MD20Q42 and revieved it without the remote. I need to get the television to memorize all channels so I can click the channel up and down buttons but my universal remote...
One option: get a replacement original remote from remotes.com.
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=MD20Q42&uuid=12693227936230 (direct URL)
The other option is to get a higher end remote that can be programmed from your computer to match the TV's remote (but check if your tv is supported first).
I hope this helps.
Mar 03, 2009 | Toshiba MD20Q42 20" TV/DVD Combo
Toshiba MD20Q42 20" TV/DVD Combo Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
