Question about Vector 2M Pwr Rch Spotlight
3.5"x1.5"x1.5" 6V3AH is a SEL DMU6-3 rechargeable lantern bought at home depot last year.
I found a replacement battery at interstatebatteries.com. Search for DMU6-3, you'll find 6v 3ah SLA 187/250 Faston for $10.00.
Posted on Mar 20, 2010
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
I need to buy a drill/driver for DIy at home, I am medium skilled handy. Do the batteries in the battery operated ones die if not used/recharged regularly. What are the medium to good avilable.
The battery tools are the way to go, the batteries last a couple years or more. I have a couple that are almost 5 years old. For the home and light construction I would go with the Ryobi 18 volt. The price is very good and they are very dependible. Think about a set (drill, circular saw, reciprocating saw, and flash light) they will all come in handy around the home and sets are cheeper. You can find them at Home Depot
Jan 19, 2011 | Dewalt Home Fencing
I tried to replace the demo batteries and now I cannot get the lantern to work
I had the same problem initially with this toy. I tried to replace the factory batteries with regular AAA alkaline batteries with no luck. I went to a specialty battery shop to try to find the carbon zinc replacement batteries also with no luck. When I got home I remembered that I had a basket full of rechargeable batteries of varying sizes so I thought that I would sift through them to see what I had. I found three of the Rayovac 15 minute rechargeable NiMH 2000 m A h AAA batteries and I charged them up just to see if they would work in the toy- THEY DID!!! I would imagine that any battery like this would work whether it was rechargeable or not- and they're probably a little bit cheaper too. I hope you have good luck making your lanterns sing and glow again too!
Dec 27, 2010 | Creative Design Disney Tangled Glimmer n...
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
I just baught a used rechargeable lantern, and
What is the Name Brand of lantern you have?
Feb 20, 2010 | Camping, Backpacking & Hiking
Need a new hose where can i get 1
lowes or home depot carry some good ones
Sep 12, 2009 | Garden
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 | Dryers
Vector 2M Pwr Rch Spotlight Logo
1,749 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
