Question about Linksys Wireless-G Broadband Router
Need to find my password
I have a wireless adapter for my Tivo and it's causing me some trouble since we added a digital conversion box. I need to access my linksys password. I can't seem to find it. I typed in what I thought it was but it was wrong. How do I find it?
    Scholar:
  • 78 Answers
1. Access the Linksys webpage
*To access the linksys gui
a. connect your linksys to the computer via RJ45 (ethernet cable)
b. Open internet explorer and on the address bar type 192.168.1.1
c. A pop-up will ask for a username and password
c.1 username and password is both admin
c.2 username admin and password blank
c.3 username blank and password admin
d. If none work reset the modem at the back of it there is a reset button "warning if you reset the modem it will be reset to factory setting and you need to setup your router again"
e. disable your computer firewall
2. Contact you ISP for assistance setting the Linksys
Posted on Nov 16, 2009
Testimonial: "Thank you so much for the helpful advice. I was at a loss and you really helped me out. I will put the information to good use. thanks again"
Why am i getting a Temporary Service Connection error message?
Did you go into Settings, Phone and Network, Change network settings, and inform the TiVo of the changes, especially to the SSID (which you should not be broadcasting)?
I'm pretty sure the TiVo doesn't need to know the router's password, if you mean the password you have to enter to access your router via a web browser for purposes of changing settings on it, although if you're running any kind of wireless encryption on that router the TiVo will need to know whatever password is associated with that.
And while you're at it, consider giving everything on your home network that doesn't leave the house a fixed IP address that lies outside of your router's DHCP address pool, and making that address pool only a little bit bigger than the number of devices you anticipate needing an IP address assigned via DHCP once you've handed out fixed addresses to everything that doesn't travel.
Jul 13, 2014 | Tivo Series2 TCD649080 Video Recorder
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
Tip
Mac TiVo Converter for iPad-Convert HD TiVo to iPad How to convert TiVo for iPad...
How to convert TiVo for iPad on Mac? To solve this problem, you need to transfer TiVo to your Mac and then convert them to iPad mp4 format with TiVo converter. With our recommended software, you can convert TiVo to iPad mp4 by yourself fast and easily!
How to convert TiVo to iPad mp4 step by step
This guide has 3 parts:
Parts 1: Transfer TV shows from TiVo to Mac
Parts 2: Convert TiVo to iPad MP4
Parts 3: Sync MP4 to iPad
To transfer TV shows to Mac, you need to download TiVo Desktop Software for Mac
Parts 2: Mac TiVo Converter for iPad
After you transfer TiVo files to your Mac, you can convert them to iPad mp4 format. First of all, Download TiVo to MP4 Converter and launch the application. Then follow the steps below:
Step 1: Import TiVo files to TiVo Converter
Enter Media Access Key for your TiVo files from "Option" button and then load TiVo files to the TiVo converter.
When your TiVo is connected to your home network, TiVo Desktop provides you with a list of available shows for transferring to your Mac.
Hints: TiVoToGo Transfers system requirements: TiVo Series2 DVR, TiVo software version 7.1 or later, TiVo Series2 box must be connected to your home network using a wired or wireless USB network adapter.
Step 2: Edit TiVo files
Editing functions are available by clicking "Editor" button in the menu bar. You can crop, trim, add text/image/video watermarks, replace audio, add special effects, etc. you can check "Apply to all" to apply the present settings to all the TiVo files.
Step 3: Choose iPad MP4 output format
After you finished editing, you then choose output format from "Format" drop-down list and specify the format under iPad profile among the three options.
Step 4: Convert TiVo to iPad MP4
Click "Convert" button to start Convert TiVo to iPad mp4. Check "Merge into one file" to join all TiVo files to one output mp4 file before start conversion.
After converting your TiVo to iPad format, you will get mp4 file(s) in destination folder. Then you need use your iTunes to transfer the mp4 file(s) to your iPad device. You may refer to the help document of your iTunes to learn how to do, or you may follow the steps below:
1. Connect your iPad to Mac. And then launch iTunes.
2. Click "File->Add File to Library...." to choose the generated mp4 file
3. Drag the videos you just added to iPad icon.
Now you are free to enjoy your TiVo recordings wherever you go.
on Jul 31, 2010 | Cell Phones
Tivo Premier xl4 won't work right with Charter Cable tuning adapter
You need to have a cable card from Charter inserted into the TiVo, and it'll have to be "paired" with the equipment at the cable company's head end, and on top of that, if they do what's called Switched Digital Video, where some channels have to be specifically asked for every so often to get put on the cable at "some carrier frequency", you need what's called a tuning adapter which is a separate box that connects to the TiVo via a USB cable, and which also connects to the cable company cable (best way is with cable splitter so that one leg "dead ends" at tuning adapter).
First you need to take the tuning adapter out of the system entirely and make sure the cable card is working. Then you can add it back into the mix.
And you may need to harass Charter's customer service department a lot to get this stuff to actually work.
A good place to ask further questions about this is the TiVo Community Forum (which is not an official TiVo, Inc. site), which is where lots and lots of knowledgeable TiVo users hang out and help each other.
http://www.tivocommunity.com/tivo-vb/index.php?
Feb 14, 2014 | Tivo Televison & Video
DriverAg0100 Driver Download
You don't need a driver for the Tivo AG0100... you plug it into one of the USB ports of a TiVo DVR and configure it from the Settings & Messages -> Settings -> Network -> Change network settings menu in the TiVo DVR.
Jun 10, 2013 | Tivo AG0100 Wireless G USB Network Adapter
We have lost the original disc that came with the TIVO and I need to get the Tivo wireless network adaptor set up on our wireless network. How can I do that without the disc, is thee anyway around that ?
The disk us usually not necessary. If you are using a series 2 TiVo you just plug this in to the back of the TiVo and it will recognize it. In the TiVo menu find Network Settings. If you select change network settings it will ask you to select your wireless router and ask for the password to your router if you are using one.
Dec 31, 2010 | Tivo Wireless-G USB Network Adapter
Trying to configure my wireless n adapter from tivo i have connected my adapter to my desktop with the ethernet cable but cannot get the website i was instructed to go to for the setup wizard the sie is...
I hate it when manuals do that, its not always that address.
Ok, (I am assuming you run windows here)
In the start menu, open "run" (or hit windows key + R)
in the run box type "cmd" and hit enter
in the black window that pops up type "ipconfig" and hit enter
now providing you are connected to the router, the address listed as "default gateway" is the one you will need to put into the browser to access its configuration.
Oct 31, 2010 | Tivo AN0100 Wireless N Network Adapter...
Adapter does not detect wireless network
Check to see if is compatible with tivo.
Some units are not compatible with tivos...
May 30, 2010 | D-Link Air DWL-122 802.11b Wireless...
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
