Question about KWorld PVR-TV 305U (KW-PVR-TV305U) Video Capture
The TV channels are shown fine, but without sound. My multimedia files sound properly.
  • anfoc Jan 10, 2008
    same here
    New Friend:
Hi, I had the same problem, I downloaded the driver from this link:
http://www.kworldcomputer.com/download/download_pvr-tv305u.htm
This solved the audio problem
Posted on Feb 24, 2010
The sound has a seperate driver that should be installed, u'll find it in the website
Posted on Jan 12, 2008
6ya staff
SOURCE:
When I try to play a cassette the cassette clicks on and turns normally. However, all it transmits to the TV is wavy lines and no picture of sound. The TV does not show the play, stop,etc. indictators when...
The TV channel should be set on Chanel 3 or Chanel 4.
Use the remote control of the TV to set it.
You can also use the AUX ports (to TV) on the VCR and connect the three wires to the AUX ports on the TV (TV input). The two audio wires are to be connected to Audio in and the Video signal to the Video input.
If you get a garbled picture you can use press the tracking button on the VCR. Usually you press the Channel Up arrow, or Channel Down arrow to adjust the picture.
Dec 22, 2013 | Goldstar Televison & Video
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
Feb 24, 2013 | Emerson Televison & Video
Inserted a usb in the side panel but cannot work out how to view the usb - whats setting do I turn the tv 2
find out wheather the usb drive is working on other tv/ computer or not. files in the usb drive must be matching with the formats supported by tv. in order to access these files go to menu & select storage device/multimedia/usb drive & see files are shown there.
Aug 25, 2011 | Televison & Video
Hi my lg lcd model no 42LB9DE works fine apart from 1 tv channel has perfect pic but no sounds have re-tuned tv many times to no avail... any ideas ? Tv antenna is is proper working order only 1 channel i...
by reading your problem the main thing is that your tuner of the tv is faulty or it can not tune the specific frequancy of the channel and its audio frequency just replace your tuner card
Feb 16, 2011 | LG Televison & Video
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
ESA plasma TV model pdp 4294lv1 does not work
my esa plasma tv model pdp 4294lv1 has sound and i can switch the tv channels, but the color is blurrier
Jul 22, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Sci Atlanta 8300 DVR HD sound in HD channels soft - analog channels OK
Experience has shown that with this relatively new mode of transmission, audio levels can be quite dynamic. If your set provides it, you may try turning on "Audio Compress" or whatever the name might be. Could also be called Dynamic audio also or some such. Reason for all the hubbub is that along with HD, mixing engineers are also providing the most range for the audio dynamics as well the most video composition info in the new broadcasts...Accordianman.
Oct 11, 2007 | Televison & Video
RCA P46922 No picture, good sound
This is due to the screen will not get the exact grid voltage. Without getting the proper screen voltage black current section will not allow to flash the channel continuously. This can be solved by adjusting the exact G2 voltage. More the deflection area is free from dust and moisture to avoid the same problem infuture.
Sep 14, 2007 | RCA P46922 TV
TV or Satellite Box Problem?
Do you have a VCR or DVD recorder? If yes, set it to record what you are watching. After a "blackout" rewind the tape and review it. If there is a blackout on the tape, the problem is the sallite box, if not, it is the TV! QED
May 23, 2007 | Sound Ideas Twentieth Century Fox -...
KWorld PVR-TV 305U (KW-PVR-TV305U) Video Capture Logo
370 people viewed this question
Top KWorld Televison & Video Experts
Ekse
Marvin
Marvin
Miroslav Totovic
Level 1 Expert
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
