Question about NRS Golds Gym Preview 1000 Treadmill
The belt stopped suddenly and now won't work anymore
The belt stopped suddenly and now will go for a minute and stop. Is this the motor or the belt?
    New Friend:
  • 64 Answers
I would check your speed sensor. I've never seen one of these just stop suddenly. But running for a min or so is one of the signs a speed sensor gives you.( especially if the treadmill want speed up while it running) Check this out and if it"s not the problem get as much info as poss to help diag.
Posted on Nov 18, 2009
Tip
2004 Freestyle Engine won't turn over.
The oil light started coming on and off after an oil change. The car was parked by the road idling when it just suddenly stopped. The starter won't even crank the motor anymore. Do you think the engine could be seized? Has anybody else had this happen?
on Feb 20, 2014 | 2004 Ford Freestyle
Treadmill runs but suddenly stops after 10 minutes
You should lubricate walking belt , check the deck for wear , too much friction between walking belt and the deck may cause the motor to shut down
jbassembly
Dec 29, 2014 | Exercise & Fitness
Why won,t my toro z4200 zero turn mower go forward or back model#74360
Hi there, I assume the motor runs as usual, and doesn't cut out when you try to move forward or back. That would be a different problem than what I'm thinking about now:
If you look underneath at the transmission belt (this usually goes from the motor pulley to the rear transmission / diff) and see if it has fallen off a pulley, or disappeared completely. This would stop the forward or reverse drive of the mower. If this is the case, a new belt should solve your problem.
Jun 12, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Car slowed down and stopped now won't start
see if the timing belt\chain is broke,normally when it brokes the car slow down and stops and dont start anymore.
Nov 13, 2012 | 2004 Volvo S40
Heard a belt break on my 1998 Hyundai Accent, but the engine didn't stop. What could it be?
you have torn an alternator, an air conditioning or power steering belt if equipped. check that the air conditioning works and gets cold if it used to and the power steering is not heavy if the car had it. if you broke an alternator belt your dash would be a christmas tree. if it had aircon and it doesnt work you need to look for your air con belt on the passenger side of the motor. if its not any of them something else has failed not applicable to any of them and it needs to be looked at asap.
Oct 10, 2012 | Hyundai Motor 1998 Accent
Belt stop working. All lights lit.
HAPPILY WALKING ALONG AN THE MOTOR JUST STOPPED. aLL OTHER CONTROLS STILL WORK. jUST THE BELT AND MOTOT WON'T FUNCTION.
iS THERE A PART ON THE POWER SUPPLY THAT HAS BURNED OUT?
May 16, 2010 | Nordic Track /proform Treadmill...
My proform 410 trainer stops working correctly after 20 minutes. The belt suddenly stops moving. When you step off it the belt is barely moving at a crawl. When I took off cover that is over motor, I...
it sounds like you may have the belt adjusted too tightly and it's putting an increased strain on the motor. there are adjustment screws (allen head) for the rear roller. turn them both counter clockwise to loosen the tension on the belt. be sure to keep the number of turns equal to keep the belt straight.
Feb 18, 2010 | Optics
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Blower Motor Works but receives no power
It's either your blower motor switch or you have a short in the wiring from your switch to the motor or you have a bad relay.
Jun 10, 2009 | 2002 Nissan Maxima
NRS Golds Gym Preview 1000 Treadmill Logo
1,078 people viewed this question
Top NRS Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a NRS Exercise and Fitnes Expert? Answer questions, earn points and help others
