Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
CRT keeps turning on & off. - Hitachi 51F500 51" Rear Projection HDTV-Ready Television
  • 4,402 Answers
First thing i would try is replacing the convergance ic
Posted on Jan 10, 2008
After 5 minutes the picture goes red
That model is famous for having CRT issues. Chances are the Red CRT or one of the CRT drive board is whats causing the issue. Usually if the set shuts down shortly after turning all red then its the CRT. But if it just turns red and keeps working it could be one of the CRT boards dropping out causing the Red to become dominate.
Jun 19, 2012 | Sony KP-57WV700 57" Rear Projection HDTV
The red crt on my 55PW9363/17F keeps flashing and clicking i turn it down till its off and it stops. any suggestions?
sounds like the RED CRT Drive board has an issue. Most likely solder issues on the CRT socket on that board. If the board appears fine the CRT itself would be suspect then.
Jul 22, 2010 | Philips 55PW9363 55" Rear Projection...
Crt monitor turned orange and the monitor menu keeps popping up
probably its old or try to check the color status in display property in desktop properties
Apr 21, 2010 | SAMTRON 55V 15" CRT Monitor
We have a Pioneer SD P5006 Television and it keeps turning off.
Ur hight voltage transformer it dead.
The Fly Back Transformer the black plastic square block with the red wire with the cap to ur CRT(tv tube) is dead.
Aug 25, 2009 | Televison & Video
Samsung 26" (CRT) HDTV won't turn on...
Since the set works some of the time, I'd first look for poor connections. One thing to keep in mind is when the set does NOT work properly. does that occur more frequently with heat? cold? Humidity? If you can solder, first try resoldering any connecitons on the boards that appear grainy or have rings. If that does not resolve the problem, look for patterns for when the set fails. Those patterns will help to narrow down the possibilities.
Keep me posted,
Sep 05, 2008 | Samsung TX-P2670WH 26" TV
AOC 17" Flat CRT Monitor
Could be problem of key switches!
Try replacing or check for leakage,high resistance across switches using ohmmeter.
Jul 26, 2008 | AOC CT720G 17" CRT Monitor
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
This can be a short in the power supply, scan circuits, or the CRT circuit, or the CRT itself. The set would have to be troubleshooted by an experienced tech to find out the cause of the failure. I can tell you in advance that your set may not be worth to service.
Jerry G.
Feb 09, 2008 | Polaroid TTM-2401 TV
Monitor problem
This monitor is bad replacement is the only option as the CRT monitors are obselete you could get a good deal on one if you are not shopping for a flat panel!
Oct 24, 2007 | Samsung 793S 17" CRT Monitor
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
