Question about Citizen Eco-Drive BL5184-56L Wrist Watch
Date setting on Citizen 0510 chronograph
I have received a Citizen 0510 Chronograph wristwatch as a Christmas present. It is not a perpetual calendar watch but does have the date at the 3 o'clock position. I have set it according to the manual and it doesn't keep the correct date. I have tried setting it in the evening and in the morning but it always seems to either be a day ahead or behind. Please help.
  • Anonymous Mar 24, 2014
    How do I adjust the date on my technomarine ys16 watch to automatically follow the calendar date? It does not follow the date after the 31st. It is always behind. I need a permanent solution for this. I want it to function like any other normal watch would. Thanks!
  • Anonymous Mar 31, 2014
    I have a citizen e650 and whilst I can set the date and the time and the appropriate time zone I cannot set the day to either Sunday or Monday...when I check the power reserve the gauge goes past maximum to the Tuesday position!!! Do I need to send it off to citizen for repair?
    Sniper:
  • 73 Answers
Try this method. Set the date until it reads a couple of days in the past and then set the correct time. Of course do not touch your date or time settings between the hours of 9PM-1AM. Wait until the next day, then move the hour hand forward until you reach the current date with the correct time.
Posted on Jan 09, 2008
    New Friend:
Pretty easy, I got the same problem.
-adjust the time to midnight
-adjust the date to today
-adjust the time of the day afterward
Posted on May 02, 2013
    New Friend:
  • 161 Answers
Try the citizen web site, most user manuals are available to download
Posted on Feb 01, 2008
6ya staff
SOURCE:
The stem on my citizen watch is turning but not changing the time or date any ideas what is wrong ?
put your finger nail under the crown and pull it out a bit ,then turn it to adjust the hands . when finished push it back in
Apr 15, 2015 | Citizen Watches Citizen Eco-Drive...
Tip
Watch glossary: C (part2)
C0Ck, see bridge.
COLIMAçONNAGE, see snailing.
COLUMN-WHEEL
Part of chronograph movements, governing the functions of various levers and parts of the chronograph operation, in the shape of a small-toothed steel cylinder. It is controlled by pushers through levers that hold and release it. It is a very precise and usually preferred type of chronograph operation.
COMPLICATION
Additional function with respect to the manual-winding basic movement for the display of hours, minutes and seconds. Today, certain features, such as automatic winding or date, are taken for granted, although they should be defined as complications. The main complications are moonphase, power reserve, GMT, and full calendar. Further functions are performed by the so-called great complications, such as split-second chronograph, perpetual calendar, tourbilon device, and minute repeater.
CORRECTOR
Pusher positioned on the case side that is normally actuated by a special tool for the quick setting of different indications, such as date, GMT, full or perpetual calendar.
COSC
Abbreviation of "Contrôle Officiel Suisse des Chronomètres" the most important Swiss institution responsible for the functioning and precision tests of movements of chronometers. Tests are performed on each individual watch at different temperatures and in different positions before a functioning bulletin and a chronometer certificate are issued, for which a maximum gap of -4..+4 seconds per day is tolerated.
CôTES CIRCULAIRES
Decoration of rotors and bridges of movements, whose pattern consists of a series of concentric ribs.
CôTES DE GENèVE
Decoration applied mainly to high-quality movements, appearing as a series of parallel ribs, realized by repeated cuts of a cutter leaving thin stripes.
COUNTDOWN TIMER
A function that lets the wearer keep track of how much of a pre-set period of time has elapsed. Some countdown timers sound a warning signal a few seconds before the time runs out. These are useful in events such all kinds of race.
COUNTER
Additional hand on a chronograph, indicating the time elapsed since the beginning of the measuring. On modern watches the second counter is placed at the center, while minute and hour counters have off-center hands in special zones, also called subdials.
CROWN
Usually positioned on the case middle and allows winding, hand setting and often date or GMT hand setting. As it is linked to the movement through the winding stem passing through a hole in the case. For waterproofing purposes, simple gaskets are used in water-resistant watches, while diving watches adopt screwing systems (screw-down crowns).
CROWN WHEEL
Wheel meshing with the winding pinion and with the ratchet wheel on the barrel-arbor.
CRYSTAL
The clean cover over the watch face. Three types of crystals are commonly found in watches: acrylic crystal, mineral crystal and sapphire crystal .
on Jan 11, 2010 | Watches
Citizen eco drive stopped working
Bad capacitor (Titanium Ion Battery)... probably a $30 or so repair on a fine watch.
Feb 17, 2014 | Citizen Watches Citizen Atomic Perpetual...
I have a men's Citizen Eco-Drive WR 200. Why does my digital time accuracy differ by 2 mins from the analog setting? Thank you, Wayne
The analogue time can be set to agree with the digital time by following their instruction manual.
If you go to http://www.citizenwatch.com/COA/English/settings.asp and follow the instructions, you can download the ones for your watch.
Sep 28, 2010 | Citizen Eco Drive Chronograph Perpetual...
The second hand doesn't move . i tried pushing the buttons in the chronograph mode, the time mode and nothing. i have a citizen eco-drive BL5260.
I assume that you do not have any instructions for this watch.
If you enter "www.citizen-signature.com/#/settings/" you should arrive at the page for your watch.
You can download the manual or look at sections.
Feb 22, 2010 | Citizen Perpetual Calendar BL5260 50E...
Citizen Eco-Drive chronograph World. Top left button??
It is hard to say not seeing the watch as different watches has different means of push or screw-on buttons. If your watch has a 200 metres mark on dial, then it can be the Helium valve, but it's just a guess. To make sure you'll get the right info, paste this link into your browser:
http://www.citizenwatch.com/CUK/English/identifycaliber.asp
Find your movement caliber number and follow instructions.
If you can't find what you are looking for, upload full watch details here and I will try to find out.
Do not forget to rate, please.
Jan 04, 2009 | Citizen Eco Drive Perpetual Calendar...
Set date on a citizen eco drive perpetual calendar
You should be able to pull the crown out ( the piece on the right hand side that sets the time) half-way. Your watch has three settings for the crown: all the way in, half-way out , and all the way out that sets the time. Pull it half way out and turn the crown clock-wise. You should hear a click when you do this. If the date dosn't change turn it again. The date should move for you. If you find it dosn't please let me know , and I will be glad to research the answer for you. Good luck!!
Sep 29, 2008 | Citizen Watches
I have a wristwatch I need instructions for, how to set correct time and use the alarm and stop watch features. It is an
I was giving a Rolex Oyster Perpetual Date Just its a dupl.but i don't know how to set it. could someone help me with this
Aug 02, 2008 | Watches
Citizen Eco-Drive BL5184-56L Wrist Watch Logo
1,635 people viewed this question
Top Citizen Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Felipe Valera...
Level 1 Expert
Are you a Citizen Watch Expert? Answer questions, earn points and help others
