Question about Zenith Z56DC1D 56" Television
Why does my yard light not put out enuf light?
I have a homemade 12vdc yard light.I bot a transformer,120 vac in, 12 vdc out. why is this insufficient to properly light the two 1156 (auto backup lamps) that I have had in this yard light for 20 years? (Orig xformer burned up)
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, other than the posted voltage (12VDC OUT), the output current is equally important. The current is half responsible (aside from the voltage) in lighting up the bulbs to its rated brightness (wattage). If for example, each bulb is rated @ 12V / 5W, then it would require the equivalent of 2 X 0.5 Amps (500mAh) or 1 Amp. The higher the wattage, the higher the current required. Incidentally, if the wires are small and long (bulb far from transformer / power supply), then the output voltage may need to be higher a bit to compensate.
Additionally, checks (if have not been done) should be made on the wires, connectors, sockets for possible loose, corroded, grounded or anything out of the ordinary.
Good luck and thank you for asking FixYa.
Posted on Nov 16, 2009
The converter on my motorhome does not convert 120vac to 12vdc anymore what could be the problem
Make sure that the the down transformer is good. That being the case then the items to check are the rectifiers- usually diodes that convert current from ac to dc. They all have to be working.
Mar 21, 2016 | Electrical Supplies
I have some outdoor landscape lights that were working fine until a few days ago. The 120 vac power goes into the first transformer, and then out, and into a second, then a third, then a fourth, and...
Hi, to isolate the faulty transformer, one need to obtain a Multimeter and set it to Volts AC, then going to the Output of each transformer & see if there is the required 12V there. The one that's NOT providing an output is the faulty one.
In these setups you are correct there is little else it can be. However check at the connections to the lights also, see if there is Voltage there too.
A transformer will have the 120 V AC on the Primary, INPUT side, and 12 V AC on the Secondary OUTPUT side.
Try testing right on the transformers terminals. Also remove the "Load" too when making measurements as if there is a short etc, then that may give a false reading. Always measure Voltages first with NO load, then test again with the Load, they should both be the same, if NOT then you have a fault NOT in the transformer but elsewhere in the circuit.
Sep 26, 2010 | Garden
I bot and installed a transformer (120v in,12vdc out). See beow
You have a good idea but with the transformer you may not have enough amps to get full power out of your bulbs. Be sure you have a good ground at the trans, These bulbs are not as bright as you might be thinking with out the proper reflectors. You might try a sealed boat trailer type of light w/ a clear cover. Check out wally world, boat supplies, or a simi trailer parts supply for a good tag light.
Nov 14, 2009 | Electronics - Others
How do i excite a coleman sport 1850 generator?
This unit is capacitor excited, simply pull the terminals from the capacitor and apply 12vdc to the the wires for about 1 second. Then plug capacitor back in reassemble and run generator and check voltages. If the rotor magnetism has been restored and everything else is good you should be producing power now.
There is an alternative way to excite back end but it is a little more dangerous. It involves starting the unit and then applying 12 vdc to either of the 120v outlets for less than a second. This is the best way but it is more dangerous because once the back end is excited the outlet will now be putting out 120 vac. So if you leave your 12 vdc source connected too long you will back feed that source with 120vac. What we've learned to do is to have 2 wires coming out of the outlets with the tips exposed then we take our wires with the 12 vdc source and just brush them quickly against the 2 wires coming out of the outlet.
Nov 05, 2009 | Coleman Sport 1850 Generator
Why won't it turn on?
Sounds like you need a new battery. When they go dead you will still see the green light but it will not turn on or only on for a second.
Sep 03, 2009 | Schiller Cardiovit At 2 Light Ecg Machine
Tips how 2 wind transformer ac -dc .output 12volts. in put 240
your windings of primary to secondary must be in a ratio of 20:1. That is, for a primary with say, 100 windings and input 240 VAC, 5 secondary windings will give you 12 VAC. you need to rectify then regulate if you want 12VDC. Just buy an off the shelf wall-wart.
Jul 13, 2009 | Bose Lifestyle 18 System
Refrigerator totally inop. 120 VAC & 12 VDC present. Unit is model # RM3662.
Using one of the two power supplies is there any running sound. It is important that the van is not blocked by lint. The fan is easy to stall with spider webs and dirt. good luck
May 23, 2009 | Dometic RM2852 Refrigerator
Tv/dvd will not play when use ac plug
The 120 VAC to 12 VDC transformers they supplied with the TV are VERY prone to failure
Nov 25, 2007 | GPX TV6000 9 in. TV/DVD Combo
Zenith Z56DC1D 56" Television Logo
20 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
