Question about Refrigerators
The coolroom motor seems not to switch off at times, especially when humid and the coolroom will freeze up, it has had a new thermosate installed and will only happen every now and again, but has been happening for a while now, and has be installed in house 4 8 years. Only problems over last 14 months.
  • 1 more comment
  • Deb Manwaring Nov 16, 2009
    Hi, i am wondering why this seems to happen when there is a weather change, ie humidity around
    Hey i was wondering why this problem seems to occur during a weather change ie humidity in the air
    Where is the best place to get a fail-safe thermostat and is this what it is called thank you
  • Refrigerators Master
  • 19,396 Answers
Hi.
Ensure that the door seal is guaranteeing proper insulation, or that will be causing the problem in humid weather condition.
I assume that the thermostat replaced was the room temperature control thermostat.
There is another kind of thermostat or control to be tested.
Near to the fan and condenser coil you will find defrost system. This is needed to melt ice on cooling coil located outside the room.
The defrost system is operating continuously, at fixed intervals, or when triggered by a thermostat.
Have a technician checking defrost system.
Check the door insulation first.
Posted on Nov 16, 2009
    President:
  • 1,865 Answers
The thermostat controls a motor control relay which in turn controls the motor. When you have an intermittant problem like this, you have to use monitoring meters to find out the component that is failing to shut down.
We normally use a chart recorder that would monitor the thermostat and the control relay (and anything else in the circuit) If you don't want to go to this trouble, you could install a fail-safe thermostat that controls another motor control relay in series with the existing relay. This way if the first temp control circuit fails to operate, the second will
Why would my convertible top work intermittently
Possible bad ground at top motor, bad switch, bad relay (most likely) or bad motor.
Jul 29, 2015 | Cars & Trucks
Model # MS09NW This unit has been recharged twice this year and is still freezing up. What could be the problem?
Freezing up isn't a symptom of needing charge. Any A/C will freeze up if there isn't enough air flow for the amount of cooling you ask of it, especially when it's humid.
Turn the fan up, and likely you won't freeze up.
May 16, 2015 | Heating & Cooling
Nabi 2 freezes when charging
I fit is a new tablet, I would take it (/send it ) back to supplier and complain and/or ask for a replacement.
If it is not new, then... hmmm.
Jan 11, 2014 | Nabi 2
My carrier heat pump has frosting on the outside on it's coils. I know that it's cold outside but is that normal?
Yes it is normal especially with high humidity. The moisture freezes on the coils just like on the evaporator coils in a freezer. The heat pump will defrost itself by shutting off the fan outside and reverse the flow of refrigerant to melt the ice when it build up then switch back to normal heat. That's why at times you may feel cold air coming out of the vents in the house. The outside coils are defrosting.
Dec 16, 2010 | Heating & Cooling
WE ARE CURRENTLY IN NORTHERN TERRITORY VERY HOT AND HUMID. RUNNING AC THRU THE NIGHT IT STOPS BLOWING COLD AIR AND FAN SEEMS TO BE NOISY. HAS IT ICED UP DUE TO THE HUMIDITY. UNIT BEING RUN THRU THE DAY NO...
If your coil is freezing at night, it sounds like your getting cold enough at night to have your saturation temperature drop below the design of what the AC is able to do. If it runs all day without an issue and freezes up at night, you need to add what is called an outdoor fan cycling switch. This will turn the condenser fan off when the saturation temperature drops so it will not freeze your coil at night. You need to have an HVAC technician install this. It is not a DIY projuect since it has adjustments that need to be right. Plus, it it's a heat pump, it needs to drop the switch off in the winter.
Sep 28, 2010 | Heating & Cooling
Everything seems to be working - installed a new water panel today - but the humidity level remains at about 30%.
If it is very cold out or if the humidity was very low to start with then it will take quite a long time to get the humidity back up. Do you have your thermostat set to run the fan continuously? This will keep the air flowing over the panel and bring the humidity back sooner.If you allow it to just cycle with the heat it will take a very long time to catch up.
Turn the fan switch on your t-stat to "on" and then it will circulate air all the time and help you out faster.
Heatman101
Jan 11, 2010 | Aprilaire 550 Humidifier
2 Air Conditioner Problems
Whinny noise is probably motor which needs some motor machine oil (hardware store).
Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
If you want to further pursue, let me know.
Apr 30, 2009 | Heating & Cooling
Heater not getting hot!
Could be one of many things, first check your antifreeze concentration,s/b 50/50 mix,my sis had the same problem, she used straight anti freeze, need water to hold heat.
Nov 20, 2008 | 1999 Mercury Cougar
Have bought desmon coolroom FRI171723 BUT mislaid instruction manual
have bought desmon coolroom fri171723 but mislaid instruction manual
Nov 04, 2008 | Refrigerators
Goldstar DH304 Dehumidifier
Take cover off. First check the fuse on the circuit board. If it's blown replace it. That should get the motor running, the motor might be or is going out. If the motor is bad you'll have to replace the motor. If the fuse is good and the motor is good, unhook the wires on circuit board that go to the humidity control switch. If the unit comes on with the humidity control switch unhooked, you'll have to replace the humidity control switch. Sears has them for about $11.50. Hope this helps.
Sep 13, 2008 | Goldstar DH304 Dehumidifier
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
