Question about JVC Everio Share Station DVD Burner Burner
My camera is telling me that the USB cable is incompatible. I am not sure this is the cable that came with the burner or the camera as it was given to me. What type of usb cable do I need to purchase?
    President:
  • 1,884 Answers
For this device you require a H&B Xline HDMI Male to HDMI Male Cable. It is a six foot cable. Look for it.
Posted on Nov 16, 2009
Incompatible disc???
This device either needs a firmware upgrade or is actually faulty. It cannot be anything else.. Is it in warranty with JVC?
Jul 24, 2009 | JVC Everio Share Station DVD Burner Burner
Keep getting incompatible disc error
what if you try other dvd-r brands. just a suggestion.
Sep 23, 2007 | JVC Everio Share Station DVD Burner Burner
Keeps saying disc incompatible
the problem with the reading lens.try a DVD lens cleaner.
purchase any one good DVD cleaner,then have a liquid clean.you will be given a liquid,put 2 drops in the brush behind the DVD.
then let the DVD play until it finish.
it might sole the problem.
rate me if you like a simple solution..tell me your status just comment if yo wanna know more.
PEACE>>>>
Jun 14, 2009 | JVC Everio Share Station DVD Burner Burner
Transfer video to computer
I would like to know more about this USB adapter cable you bought. The camera has a IEEE-1394 (commonly refered to as Firewire or i-Link) connection that is inherently incompatible with USB. I don't see how one cable could do the trick unless it had some kind of conversion hardware built into it. Does it have a little box on the cable or is it just a straight cable?
CNet.com says that your laptop has a four pin Firewire port on it. I would go to BestBuy and tell them you need a Firewire cable with a four pin connector on both ends. If they give you a weird look tell them that is the small Firewire plug, not the big one. If they are still confused, get somebody else to help you. Then use that cable to plug your camera into your computer. Windows should recogonize it automatically. If it doesn't there may be a problem with you camera.
Jan 13, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Disc Incompatable Problem
This burner has been bad from the get go. J.V.C.Repaired once already. Wouldnt recommend buying this product to anyone. Camera is great but needs burner to download the information now. The burner is ****! J.V.C. charged me dearly for the first repair and I feel ripped off now ! Cant download and always asks for another disc, incompatible.
Mike
Sep 02, 2008 | JVC Everio Share Station DVD Burner Burner
Jvc gz-mg130 and jvc cu-vd20
I had this problem with the GZ-MG505AA (connecting to WinXP SP3). I tried a different USB cable and it worked first time.
Not sure what is different about the cables (the original cable worked fine with my WM 6 mobile phone).
Dec 27, 2007 | JVC Video Cameras
Incompatible disk message
You need to read page 8 of the JVC CU-VD20 DVD Burner instruction manual:
Recommended DVD-R Vendor - JVC, TDK, Verbatim, SONY
Writing Speed for DVD-R is 8X maximum, this is the real issue as I first bought 16X TDKs and they did not work, so now I need to buy 8X.
That's a bummer as most stores only supply 16X now.
Nov 30, 2007 | JVC Everio Share Station DVD Burner Burner
Everio cd burner
simple as it sounds...unplug the sharestation for a few seconds. this seems to reset it and it may work for you. when you do this, turn off the camera also, kinda resetting the whole system
Aug 30, 2007 | JVC Everio Share Station DVD Burner Burner
"Connection failed" -- USB connection
The "Connection failed" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me or 2000 to use a USB connection. Your computer must also have the appropriate USB connectors. NOTE: This camera cannot make a USB connection with a computer running Windows XP. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
"Camera not connected" -- USB connection
The "Camera not connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me, 2000 or XP to use a USB connection. Your computer must also have the appropriate USB connectors. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
Sep 21, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
JVC Everio Share Station DVD Burner Burner Logo
97 people viewed this question
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tre Elkins
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
