Question about Motorola Mobility Q9m Smartphone
My motorola q9h global wont charge. the ''charging'' glow comes on when i plug it in but it just glows and never turns on...
  • patrat13 Nov 16, 2009
    well, it is newish however, i bought a new chager and battery, it still wont charge and im afriad my charginf port is burnt out....if it is then my warranty won't cover it (I checked)
  • 945 Answers
Ok i`m presuming this is a newish phone, go to your nearest dealer, while you are there ask them to see if your charger is faulty. If it isn`t try a new battery.
Posted on Nov 16, 2009
  • william bennett Nov 16, 2009
Batteries keep going flat
No it does not, there is no connection.
If the alternator was not charging, your charge light should glow to tell you that. If the charge light is NOT glowing while driving, then you simply have a dying battery which cannot hold a charge for long.
The oil light not glowing when the ignition is turned on shows only that the globe has failed.
Jan 25, 2014 | 1997 Mitsubishi Montero
2006 dyna street bob, fuel injected
Hi Anonymous, running hot and glowing pipes is almost always caused by retarded timing. Battery not charging could be voltage regulator and or alternator. Quite a mess, for more info please visit website below and good luck.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jan 04, 2014 | Harley Davidson Motorcycles
How to charge the starter
Stephan, plug the wall charger into an outlet, then attached the glow driver to the end of the cable same as you would if attaching it to the glow plug. Generally and push and twist. When you get it on there, a charge light on the charger will light up. Let it charge overnight. Good luck
May 11, 2011 | Duratrax Ultra Slim Aa Glow Starter
My plantronics explorer 260 won't turn on. Also when I go to charge it the charging light stays on for about a few min. and then shuts off but i still can not turn it on. Please help
Here are a few steps to review before coming to the realization that your battery could be wasted. Give them a try and see if it helps any.
1) While your headset is charging, the indicator glows red. When your
headset is fully charged, the indicator turns off.
2) Turn off the headset: Press and hold the call control button until the indicator glows red. You will hear descending tones. When power is off, indicator stays off.
3) Turn on the headset: Press and hold the call control button until the indicator glows blue. You will hear ascending tones.
Good luck from Headsets Direct!
Feb 24, 2011 | Plantronics Explorer 232 Bluetooth Headset
The thing you put on the back of the truck will not work only the motor lite comes on but i no its not the glow plug
Have you charged the battery in the EZ Start wand? If you have is the motor turning over at all? If the motor is turning over but not firing it could be the glow plug. If the motor trying to turn over but won't, the engine might be flooded. If it is flooded remove the glow plug and turn the truck upside down. Fuel will run out of the engine. If fuel runs out of the engine, put the truck back down on its wheels. Cover the engine head with a rag and turn the engine over with the EZ Start wand with the glow plug still out. This will remove all excess fuel from the engine. Reinstall glow plug and try to start again.
Oct 21, 2009 | Traxxas Rc Nitro Stampede Rtr 2wd Monster...
1984 urvan diesel wont start
you have a bad glow plug relay. yes its that simple!! hope this helps you !!!!
May 30, 2009 | 1990 Nissan Minivan
Oven will not light
Hi!!! Even if your ignitor glows just change it it has a weak charge..Also if you change glow ignitor and it does not come on then your gas safety gas valve if shorted good luck..
Jan 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Razr phone backlight stays on while charging
hi,
  dis is common in razr and samsung higher models...d backilight ll glow when u put d mobile on charge...i have a samsung d840 metallic series phone, d backlight glows througout d charging period..my friend has a razr and in tat also it glows when it is charged...so its common in razr and samsung..nothin harm to d mobile because of this....
good luck
Jul 04, 2008 | Motorola Mobility RAZR V3
The charging light always glows
Battery issues were supposedly corrected with the latest firmware update. Download the firmware and perform an upgrade. Let me know if this solves your problem.
Cheers,
JoRick
Mar 18, 2008 | Creative Labs Zen Digital Media Player
Motorola Mobility Q9m Smartphone Logo
399 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
