Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
I have a Poulan Pro Blower PPB2000LE rope came loose so I took it a part and now I don?t know how can I rewind the rope with the spring, should I use clock direction or the other direction.
  • 486 Answers
It is not a question of clockwie or not, it depends on the direction of rotation of the engine, they are not all the same.
*wind the rope/spring in the direction that the rope would pull the rope rotor.
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Posted on Nov 16, 2009
I have a poulan pro bvm200fe blower wind cold cord will not return on isn't own
Suggest that the rewind spring is broken on the end.
Disassemble rewind to inspect return spring
Jan 17, 2017 | Poulan Garden
Why won't Lawn mower pull cord rewind ?
the springs break when jerked too hard and more than the rope lenght
Jun 28, 2014 | Poulan Pro " Pro" Self Propelled Mower
Poulan lawn mower cord won't retract
New or used unit? If new can you return it ? If not you will need to take the recoil assembly off the engine and rewind the spring. Check inside the recoil assembly to see if the spring is broken or just popped out of place on either end. If it is broken your done. You will need to find a Poulan dealer to get a new spring. If new take it to a Poulan dealer for warrenty replacement. If you want to try to rewind the spring look to see where one end of the spring fits into the housing and the other into the spool. On the edge of the puley should be a notch. Place the rope in the notch and turn the pulley it in the direction needed to wind the spring about 4 or 5 turns. If it now pulls all the rope in you are done.If not put the rope back in the notch and wind the spring tighter till the rope is all pulled in.
Jul 25, 2013 | Garden
I have a Poulan PRO LINK PP 335 and the pull rope is only coming out about 8 inches. It's stuck...what should I do?
Remove the starter and pull the cord, if the cord still only comes out so far it is either the cord is too short ( replace the cord ) or the rewind spring is coil bound ( release some of the tention )
Apr 23, 2011 | Poulan Garden
I have a poulan pro backpack blower (the 30cc one) and recently tried to start it and the rope extended all the way and won't recoil. i pulled it apart and can see the pulley inside the cover, but how do i...
The recoil spring might be broken or unhooked from the pulley. You would have to remove the pulley to find out what the problem is. But doing this, the spring could uncoil from the spring housing and it is dangerous that it could hit you in the face if you are not very careful. The spring is very difficult to rewind into the housing. I would bring it to a shop if I were you. Whatever you do, good luck.
Nov 22, 2010 | Garden
How to repair a poulan pp 136 trimmer? The rope to start won't rewind.
Most likely you have a broken return spring.whitch will involve removing the blower cover and putting in a new spring,and then reloading the tensionon it.there is trick to that but its hard to explain....you have to tuirn the rope holder the oppisite direction you want it to pull the rope in ,then you feed in the rope while holding the spring loaded then tie the string in and let go...Normally 4-5 rounds will do for a good recoil..Hope it helps
Aug 27, 2010 | Poulan Garden
Rewind a recoil starter spring. I've spent many hours trying to get the recoil spring put back in its place with no luck.
I DID THIS SAME JOB BY WINDING THE SPRING UP IN MY HAND AND THEN TOOK 2 TWIST TIES AND WRAPPED THEM AROUND THE SPRING TO KEEP IT IN THAT CONDITION. I THEN INSTALLED THE SPRING WITH THE LONG END OF THE TWIST TIE EXPOSED AND AFTER GETTING THE ROPE HOUSING IN PLACE I PULLED THE TEWIST TIES OFF WITH SOME NEEDLE NOSE PLIERS. HOPE THIS HELPS
Sep 25, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Rewind don't work
as you put the side with the recoil starter back on the saw, ensure the rewind pack isn't binding. before tightening the screws, pull the rope out a few inches and let it rewind. if it won't, something is binding. keep moving the side panel till it will rewind. I have done this before myself. get it all put back together and it won't work.....
Jan 29, 2009 | Poulan Pro Chain Saw 46cc 20"
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
388 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
