Question about HP Deskjet F4180 All-in-One InkJet Printer
Went i sent to print he makes a big noise and get error
    President:
  • HP Master
  • 2,017 Answers
It is require servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Posted on Nov 16, 2009
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Does my printer give a confirmation after faxing is completed?
Normally if i fax is sent, it will just give a message as Fax sent or it wont give any error.
But if you want to get a confirmation whether the fax is sent or not, you can print a fax confirmation page on ever fax sent or received or both.
Press the SETUP button ( menu )
Scroll till you find Print Report - Press OK
Scroll till you find Automatic Reports Setup - Press OK
Choose Send Only - Press ok
Regards,
Ron
Mar 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Insert left cartridge error message. Replaced. Still an issue. My printer makes a noise - like it is trying to clear itself. Both Cartridges have been replaced. I have even unplugged the unit and it...
On the control panel of the printer -
Press the Setup Button
Scroll till you find Tools Options - Press OK
Look for Printer Alignment - Press OK
IF the alignment goes thru well, your printer will be able to print/scan/copy.
If it still makes grinding noise or makes unusual noise, Turn off the printer and open the rear access door. Clean the rollers with lint free cloth. Close the door. Open the front access door and check if the carriage moves freely ( cartridge holder ) and check for any obstruction.
If you tried the above steps and still unable to make the printer work, it could be hardware failure.
Regards,
Ron
Mar 04, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark E 250 dn printer. Keeps turning off. Switching from blue bulb indicator to exclamation point indiator. Difficult to turn back on by pressing blue arrow button
The problem could be several things, the first one could be a Flushing buffer error. That means that the printer did not understand the print job sent to it and has to be reset in order to continue printing. Second could be a memory full error where the print job sent to the printer is too big and the printer memory is not enough. The third could be the printer front door is not closing properly, make sure the toner cartridge is installed correctly and that the front door is closed. That's all I can think of right now.
Jan 12, 2010 | Lexmark E250dn Laser Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Big noise
If the printer was not making the noise before you replaced the fuser unit I would try the following:
1. remove and re-seat the new fuser unit and try a test print.
2. if it still makes noise, remove the new fuser unit and replace the old fuser unit and try a test print. (if you waited untill the printer refused to print on the old fuser this might not work).
If you don't get the noise with the old fuser, then it's possible that the new fuser is defective. You could try returning it for replacement at this point. If you still get the noise with the old fuser, then possibly it is not seated correctly or the latches aren't locked or there is some other unrelated issue.
Jun 25, 2008 | HP LaserJet 2420 Printer
Oki C5150N Grinding noise
One of the drum cartridges is stuck. Test by removing them one at a time with the printer off, then turning on.
Oct 31, 2007 | OKI C5150n Led Printer
Printing Dillema
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Oct 30, 2006 | HP DeskJet 690c plus InkJet Printer
HP Deskjet F4180 All-in-One InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
