Question about Kodak EasyShare C613 Digital Camera
Put new batteries in but there still is no power
    Scholar:
  • 78 Answers
Check if your using the recomended batteries for this camera Easyshare C613. The batteries are 2AA Ni-MH batteries, 2 AA Lithium batteries or 2 AA Alkaline batteries. If your use this kind of batteries and they are new out from the box try this steps.
1. Remove the memory card and the battery on the camera
2. Clean the both battery contacts with clean dry cloth
3. Put the battery back in the camera in correctly
4. Set the camera in Auto "it's the camera icon on the dial of the camera."
5. Turn it on
*If it turns ON take photos and review them check if it will stay on
*If it doesn't turn ON or stay ON contact Kodak support line @ 1-800-235-6325 (23KODAK). You can also try to log on to www.kodak.com/go/stepbystep.
Posted on Nov 16, 2009
No power to rogue g5 amp battery ok
Sure the new battery has power?
Did you put the battery in correct? are all contacts (in the amp and on the battery) clean and shiny?
Check all this, before you press the on button.
Feb 12, 2015 | Rogue G5 5W Battery Powered Guitar Combo...
JUST PURCHASED NEW CAMERA, PUT NEW BATTERIES IN AND AFTER TAKING JUST A FEW PICS, BATTERY LOW INDICATOR CAME ON AND SAYS IT NEEDS NEW BATTERIES. PUT NEW ONES IN AND AGAIN, BATTERY LOW INDICATOR CAME ON. ...
yes, The Flash mode consumes LOT of power, thats why it needs lot of batteries, use " rechargable batteries", or use camera without FLASH, and use GOOD QUALITY battaries
Jan 22, 2011 | Canon PowerShot SX100 IS Digital Camera
I just put a new 9 cell battery, two new 2GB ram cards & a new, blank hard drive in our Dell Inspiron 1525. But the screen does not seem to work when I turn it on, or after I put in an installation...
Remove the battery, and connect the AC power. Then, try to start it.
Disconnect the AC power, and remove the "new" disk-drive.
Then, connect the AC power, and try to start it.
Disconnect the AC power. Remove the "new" RAM, and put the "old" RAM back in.
If it does start, add the "new" disk-drive, and try again.
If it does start, add the "new" RAM, and try again.
Jan 15, 2011 | Dell Inspiron 1525 Notebook
T23 laptop. Put in new battery. WIth battery in
poor battery contacts or dead battery cell doing this flickering
replace the battery if contacts are clean inside the computer
Jul 06, 2010 | IBM ThinkPad T23 2647 Notebook
My gateway mt6840 does not read my new battery
Have you tested your power supply to confirm it's sending out the right amount of current.A simple ac tester is all you need.On the back of your power brick it will tell you your in-put and out-put voltage requirements.If your ac adapter tests good your new battery is probally the problem.
Jun 02, 2010 | Gateway MT6840 Notebook
Put new batteries in exit signs but the status light wont stay on green...it will switch back to a constant red meaning charging. What would be bringing the power of a new battery down all the time?
is the unit battery only or battery backup? if battery backup, the system is draining the batteries as it has no source of power.. if battery only there may be a connection problem or a faulty unit.
May 13, 2010 | Universal Battery Exit Sign Red Led ...
Changed battery on 2003 toyota echo but when i put the new one in and start i have no power the new battery is fully charged 12.7 volts put old battery back in car starts is there a special procedure for...
Check the new battery posts(connections if side terminal) alot of the battery companies put a protective coating on and it has to be removed. Use wire brush or sandpaper to clean them and you should be fine.
Dec 03, 2009 | 2001 Toyota Echo
No power to key pad after new battery put in
correct polarity. what battery. 9 volt or a23, did you recode combo byu hitting learn button for a second and then entering combo.
Feb 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
With new batteries already put in--no power
Are you using rechargeable batteries, and have tried lots of different batteries? Also, sometimes rechargeable batteries fresh out of the package can be dead or have very little juice. Just a thought...Hard to say that's it though if you were having the same thing happen before...
Jan 16, 2009 | Apex Digital Digitrex DSC-3000 Digital...
Car will not recognize new battery
i put a new battery in mine and was told to put in the new battery and then get in the car with door shut and turn key to on position for about 90 seconds, this worked for me, mabey it will work for you, if your battery is still hooked up you should first unhook it for a couple minutes then reconnect the battery and follow procedure. hope this helps
Jan 01, 2009 | 1997 Hyundai Sonata
Kodak EasyShare C613 Digital Camera Logo
108 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
