Question about Garden
Remington pole hedge trimmer cannot cut thick twigs like it used to when new. jams up and cam is jammed. fed up . only got 1 year out of it. It chatters and locks up. Have to take it apart, get the cam back in place and stay away from twigs bigger than 1 mm
  • 313 Answers
SOURCE: (hedge trimmer blades do not
you know what the problem is. it the motor magnetic ring that is
broken. it also called stationary parts of the motor.
Posted on Aug 29, 2008
  • 398 Answers
SOURCE: reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
Posted on Feb 26, 2009
  • 969 Answers
SOURCE: The blades move VERY slowly even when running at
1-800-345-8746
Posted on Aug 23, 2009
brector3
  • 1602 Answers
SOURCE: My Remington Titanium MS3 2700 popup trimmer will
Latch inside is broken. This mkes it difficult to use the shaver. You cant fix it to work properly but you can super glue it down if you just want to use the shaver.
Another alternative is to replace the handle portion. This is available at shaveroutlet.com
Posted on Jan 16, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Remington Axcess hedge trimmer wont run at all.
Check your fuel lines. It is probably getting air into the system. Also check inside the gas tank to make sure the fuel pick up line is still attached.
If you need more assistance please provide an exact model number and I can better help you.
Kelly
Posted on May 03, 2010
Broken won't move
Check the teeth for something jamed. Has it set up for many years, maybe rusted bar. Does the motor run? If so maybe a cam gear broken or jam. Does the teeth on the bar move when removed from unit? Or does the motor run when bar removed? To many question to ask need more info.
Jul 04, 2015 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
My homelite electric 22" shrub
That must be a pretty thick forest there Bella, Sounds like there is a jam somewhere if the thing is that new just take it back where you purchased it and they have to give you a new one or at least fix it the customer is always rite remember that..... I you tamper with those nuts you could void any possible warranty you might still have.
Apr 18, 2011 | Homelite Electric 3.7 Amp 22 In. Hedge...
Cam seems to be ok, cover is tight, but bottom blade slips off cam.
I don't think there is a solution. I found on mine that the blade had worn from wear on the cam. So the blade would slide off the cam and jam the cam mechanism.
Cannot find a replace part on the net. I am going to write Remington.
Mar 23, 2010 | Remington At3017b Hedge Wizard
Noisy, blade seizes, used two hours
Sorry but there is no help for this equipment. Remington went bankrupt and i have not been able to get parts.
Plus they,in the past, considered this a throw away unit.
Sorry for the news.
Good Day.
Oct 27, 2009 | Remington At3017b Hedge Wizard
Cutter blades and cam repeatedly jams requiring dismantling and reassembling of the blade and cam assembly.
Sorry to have to tell you this but Remington has gone bankrupt. The unit only had a one year warranty on them and when they broke, a new unit was sent to replace the broke one. It was considered a throw away unit.
Sorry for the news but that is part of being in a "disposable" society.
Good Day.
Oct 24, 2009 | Remington At3017b Hedge Wizard
Cam does not engage blade
I had this problem with mine. I ended up disassembling the two halves of the trimmer, then reseating the cam. The cam was jammed when I caught the blades on a chain link fence. Good luck and patience.
Mar 14, 2009 | Black & Decker 22" Electric Hedge Trimmer
Reassembling blades on hedge trimmer
Jan 25, 2009 | Ryobi 18V Hedge Trimmer
Trimmer safety problem
# Keep all people and animals away from the area you're working in # Hold the hedge trimmer correctly using both hands # Make sure the hedge trimmer's switched off and idle before attempting to remove any jammed cuttings # Wear protective clothing including heavy-duty footwear and safety goggles to protect your eyes from flying cuttings # Electric hedge trimmers: Don't use in wet weather. Keep the cable well away from where you are cutting and check that the socket outlet has working RCD protection # Read the manufacturer's instructions before use
Aug 27, 2008 | Walter Drake Garden Groom
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
