Question about Car Audio & Video
1999 mitsubishi montero sport wire on starter
I have a 1999 mitsubishi montero sport and I took out the starter to replace it. I took off all of the bolts and wiggled it out of place, but next to where I took off the nut holding the wires in the back there is another wire connected by a little piece of plastic, for the life of me, I cannot figure out how to unhook the plastic and wire from the starter, if someone could explain how to do it I would be very greatful. Thank you
    Guru:
  • 412 Answers
All this is a a reference wire that tells the solenoid to kick on.....If it can make it anyeasier on your part.....invest in a female spade terminal.(wire connector) and test fit it on the new starter....make sure it fits snuggly on the new one....then simply cut the wire from the old starter...wire crimp the new one together...reinstall starter....install wires...and VIOLA!!! If i can help ya with anything else get back to me.... I HOPE I COULD HELP!!!
Posted on Nov 16, 2009
Starter bendix wire routes 99 montero sport
We do not have wiring diagram here for this make and model and year. Sorry.
Jul 12, 2016 | 1999 Mitsubishi Montero Sport
How to wire up an ignition on a 1999 mitisubishi Montero sport
PDF]MITSUBISHI MONTERO SPORT 1997-2004 VEHICLE ...
alarmsellout.com/.../MITSUBISHI%20MONTERO%20SPORT%201997-...
WIRING INFORMATION: 1997 Mitsubishi Montero Sport. WIRE ... WHITE. IgnitionHarness. STARTER WIRE ... This must be bypassed when installing a remote start system. ... WIRING INFORMATION: 1999 Mitsubishi Montero Sport. WIRE.
Montero Sport Starting Problem - YouTube
? 2:35
https://www.youtube.com/watch?v=TZCbEmfi3JM
Nov 2, 2011 - Uploaded by aaron1969lopez
Im not sure what is causing me to have trouble starting myMontero Sport. ... 2001 Mitsubishi Montero Sport ...
1997-2004 3.0L V6 Firing Order -Ignition Coil Spark Plug ...
Dec 08, 2015 | Cars & Trucks
How do I install belt on alternator?
images for 1999 Mitsubishi Montero Sport belt
Montero Sport Alternator Replace 1 of 4 - YouTube
? 2:13
www.youtube.com/watch?v=Dwp14p6vBRU
Jun 22, 2011 - Uploaded by JesseHafen 2003 Mitsubishi Montero Sport alternator belts pulley auto repair steps. ... My 1999 Montero Sport Limited has 245000 miles and now is giving ...
Sep 30, 2015 | 1999 Mitsubishi Montero Sport
So where all 3 Alternators returned & tested?
Do you have wiring diagrams out ready to go
& a volt meter to start your testing?
Dec 14, 2012 | 1999 Mitsubishi Montero Sport
1999 montero sport key turns but no sound from it
Sounds like you have a bad ignition switch. It's the little box under your steering column with all the wires running to it.
Nov 21, 2012 | 1999 Mitsubishi Montero Sport
How do you remove the strater motor on a 1997 Mitsubishi Magna
Starter Motor -1997 Mitsubishi Montero Sport REMOVAL & INSTALLATION
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Engine under cover, if equipped
    • Front engine mount heat protector
    • Starter cover
    • Wires
    • Starter motor
    To install:
  3. Install or connect the following:
    • Starter motor and cover. Torque the bolts to 20-25 ft. lbs. (26-33 Nm).
    • Wires
    • Front engine mount heat protector. Torque the nut to 89 inch lbs. (10 Nm).
    • Negative battery cable Fig. 1: Starter motor mounting 9308ug03.gif
Nov 05, 2010 | 1999 Mitsubishi Montero Sport
I had the batter tested on my 1999 Mitsubishi Montero Sport. It tested good but the starter won't turn over.
Hit the starter with a hammer while some one is trying to start it and if it starts up after this the starter is bad most likely if you already checked the battery contacts in it get stuck if theres is power down to it ...starter bad....
Oct 03, 2010 | 1998 Mitsubishi Montero Sport
Mitsubishi montero sport 99 - car will not start.
could be your ignition switch, first make sure you have power going from your battery to the starter, check at the starter for 12.5 volts then make sure starter has its ground, if that isnt it test the ignition cause thats probably what it is.
Dec 10, 2008 | 1999 Mitsubishi Montero Sport
Car Audio & Video Logo
100 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
