Question about Motorola Mobility Rival A455 Cell Phone
Screen has stopped working on a A455 phone - Motorola Mobility Rival A455 Cell Phone
Getting unauthorized charger message when using universal charger for my Motorola Rival A455 phone--how to fix?
I had the same problem with my rival. I used a universal USB charger. It worked fine for a month or so and then stopped charging completely. I went to the Motorola website and downloaded the charging driver. I haven't had a problem since.
Jan 23, 2011 | Motorola Mobility Rival A455 Cell Phone
Rival A455 screen is still white even after updating the phone.
do you have warranty? if you do, then send it for waranty replacement. if not, suggest that you send it to a repair shop. replacing the ribbon is a very tricky issue. one small mistake can end up frying your device
May 06, 2010 | Motorola Mobility Rival A455 Cell Phone
Screen not coming on but phone is on
If your phone is still on the waranty, you can bring it back and you will have a new phone. The first generation of this phone has a lot of problems (I had the same than you but mine was 1 month old). Bing it back and you will have the second generation. All the bugs will be fixed
Apr 10, 2010 | Motorola Mobility Rival A455 Cell Phone
My cell phone screen is white! I don't want to take the battery out and loose my memory, so is there anything else I could do to fix it?
you will not lose your memory by talking your battery out. however, sometimes simply turning it off and back on will work. this is a common problem with rival phones. it's been happening to my phone for a week and by taking out the battery and putting it back in, but last night it stopped working. so i just called verizon today and they are sending a new phone.
Mar 26, 2010 | Motorola Mobility Rival A455 Cell Phone
Screen goes white or gets stuck in wrong mode
You have a bad flex cable. You need to have it changed. This cable is not repairable. Its a common problem for the A455
Mar 13, 2010 | Motorola Mobility Rival A455 Cell Phone
Black screen problem, motorola rival
I am having the same problem with my motorola rival. From what I hear, it's an internal issue and the whole phone is going to have to be replaced.
Jan 13, 2010 | Motorola Mobility Rival A455 Cell Phone
My screen is white
if you dropped it it may have knocked out the screen if u didnt it may have water damage or the tempurature around it may not be right and heat may have messed it up.
Jan 11, 2010 | Motorola Mobility Rival A455 Cell Phone
I have a motorola rival a455. was working fine , then yeterday I went to use it and the screen is blue with a message at the bottom that reads "bootloader version 1193." When I try to turn off the phone, I...
When a phone goes into bootloader mode, Most of the time there is a software problem. You will have to take it to a cell phone repair place to have the software reloaded. Also sometimes this happens when the unit gets wet.
Dec 03, 2009 | Motorola Mobility Rival A455 Cell Phone
Motorola Mobility Rival A455  Cell Phone Logo
87 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
