1320n I put paper in the printer the other day and then the printer stopped working
  • Judi Green Jan 18, 2008
    My printer won't print because it says 'no paper' but there is paper in it
  • Anonymous Feb 11, 2008
    replaced toner cartridge and paper tray is full and printer still says no paper refil and press start. Please advise possible fix
Smash it
Posted on Jun 08, 2008
Smash it
What does the button on the the 1320n that has a triangle with an exclamation mark mean? The light next to it is blinking and we don't have a manual.
Attention light is blinking
This state can be reached in the following circumstances:
? Paper tray is empty
? Door open
? Paper jam
? Misfeed from tray
1. Verify that the print cartridge is present and that the print-cartridge door is closed correctly.
2. Verify that media is present in the input tray.
3. Clear any jams and perform paper-path functional checks.
4. Make sure that the interlocks are operating correctly.
To reset the printer after a jam, press the GO button.(Green Button)
Sep 21, 2011 | HP LaserJet 1320n Printer
Paper jamed in front roller where paper is taken from
It sounds like your paper pickup roller is worn down and can't grip the paper to pick it up. This roller is located on the bottom of the printer. Pull the paper tray all the way out and turn the printer over and you can see it as seen in the attached picture.
This roller comes in a kit along with the separation pad and the charge roller. When you replace one its best to replace them all. The roller kit is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Oct 17, 2009 | HP LaserJet 1320n Printer
Paper jam at back roller, paper is wrapped around back roller
i don't think that is a back roller, is more than likely your fusing assembly. that would be the big roller just before the output assembly. unfortunately, once this occurs your fuser is not repairable. if you can remove the paper, this will happen again, with frequency. your best bet is to have the fusing assembly replaced. make sure you take it to someone that will guarantee the work for at least 90 days.
Sep 30, 2009 | HP LaserJet 1320n Printer
Attention light, print stops.
either you upgreat memory or print order less than 50 pages at a time.
Mar 14, 2009 | HP LaserJet 1320n Printer
I was printing in hp laser jet 1320n.....it was all going fine..but suddenly the paper got stuck in the rollers, while pritning a job. the paper is still stuck and just doesn't budge. what to do to release...
first you open the back side door of the printer and put down the two green lever and take out paer from there easily if possible clean fussing unit also.
Jan 10, 2009 | HP LaserJet 1320n Printer
Paper is winkeled comming out of my 1320 n printer
window xp.i have same problem about paper coming pcl xl error position: 8.
Oct 17, 2008 | HP LaserJet 1320n Printer
HP Laserjet 1320 Paper feed malfunction
Solution,
 take out the tray
if you look on the bottom of the machine there is a metal plate.
in the middle of the plate there is a bump
turn the tray upside down and look at the bottom, there is a small hole with a plastic lever. it is probably broken.
when the tray is slid into position the lever hits the bump and releases the lifting mechanism.
replace that part or the tray. I can get you a new tray e-mail me at
pakapala@gmail.com
Oct 14, 2007 | HP LaserJet 1320n Printer
Unable to communicate to a 1320n laserjet printer
unistall the driver completly and install again so after that click shared printer and them try it
Sep 25, 2007 | HP LaserJet 1320n Printer
1320n won't finish print job
This seems to be a Card failure- time for a replacement? is that possible?
Jun 14, 2007 | HP LaserJet 1320 Printer
42 people viewed this question
k24674
jasbo
jasbo
