Question about Sanyo PRO-700 Cellular Phone
Phone has power. but no buttons work..says 'service required, contact service provider.
Hr 725
Please press and hold your power button and volume UP button until the device powers off, then attempt to access your device after you power it back on. If further action is required, please contact your mobile provider for further instruction.
Thanks,
Dish Guy
Apr 20, 2014 | Nokia Cell Phones
Puk code for tracfone lg800g
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.For details to obtain the PUK code for the SIM card, pleaseclick on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
Jul 25, 2012 | LG800G
Trying to check the voicemail on phone. how do i do that?
If you mean the voicemail messages taken by your phone service provider when your line is busy, there are two ways normally used.
The first is to call your own number. When your message starts, press the "*" button. (Usually it's the star, but it might be different on your system. You might need to call your provider's customer service for details.) Then you're prompted for your passcode. Once in the voicemail system, voice prompts tell you which buttons to press to play messages, delete them and so on.
The second way requires you to dial a different phone number to get messages. You'll need to contact your service provider or check their website to find the access number for your telephone number if necessary.
Jun 03, 2011 | Uniden Cordless Phone
Require PUK code
Hi ,
PUK number is related to your sim card and not to ur mobile . PUK code can be given only by your service provider which is specific for each and every mobile number. You will have to give some identification as proof .
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.U can also get it from the nearest service provider .
NOTE: You should ask your service provider,get the PUK,if you provide PUK code wrongly for 7 time, you sim may become useless, then you have to buy new SIM
This solution has worked for one of my user . please click here to view
Nov 29, 2010 | Nokia 6120 classic Cellular Phone
Im looking for the procedure to unlock the fone for pantech c300
As you have not specified in particular what is the unlock code required for you, i am giving the ways to unlock all the codes
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer care department.It is free of cost.
The restriction code can be got from your old service provider..This restriction code is kept to prevent someone who stole the mobile from using it with another provider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
It is all free of cost do not pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above procedure works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4035818-need_unlock_nokia5130c_2_use
PUK CODE:
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
SECURITY CODE:
If it is lost nothing can be done. You need to flash your mobile at an authorized service center which will reset the mobile memory and also all the data inside the mobile will be lost.
Sep 18, 2010 | Pantech C300 Cellular Phone
Phone Freeze - Samsung Jet
You can get the unlock code by contacting your current service provider customer care department.If your phone is locked you can use any of your friends phone to make this call. The service provider will then provide you the unlocking codes.. Remember that the reason why the codes are provided only thro customer service provider is they will make a check on your name and identity proof at the time of your call. If the information is found to be correct and matching with their data then you will be provided with the codes. Everything is done for free of cost and you are not going to be charged for this process.This is the universal solution and is useful for many customers who are facing these kind of problems. Don't believe in any websites which provides unlock codes. All are fake. Only your service provider can provide these codes.
Thank you !!
Jul 16, 2010 | Samsung Jet S8000 Cell Phone
Puk code required for samsung j700
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Feb 26, 2010 | Samsung J700 Cellular Phone
Require 8 digit SIM unlock code
Have you tried contacting your service provider? Generally, if you explain the situation to them, they would often provide you with the unlock code and instructions.
Aug 21, 2009 | Cell Phones
L4 code on workcentre xd 155 df
TABLE 1
Summary: 'L4' Product: * Copiers & Multi-Function Copiers
  • XD Series
  • Description: XD100 Family
    - Main motor problem.
    - The main PWB sensed a main drive motor problem. Solution: document.write(ParseIncidentLinks("01 - Switch off the power and wait for 5 seconds.\n 02 - Switch on the power. If the status code persists, Please .", 'Hold down Shift while clicking to open this link in a new window', '(Click here)', 0)); 01 - Switch off the power and wait for 5 seconds.
    If the status code persists, Please see Table 2, below.
    TABLE 2
    Summary: Service Call Product: - Communication Technologies
  • Telecommunications
  • Description: A service call is required when the solution requires a Xerox engineer to rectify.
    Service will be provided in the form of an onsite engineer, repair or replacement of the machine depending on the warranty held for your specific product. Solution: document.write(ParseIncidentLinks("Please contact your local Xerox Help Line arrange a service or further assistance over the phone. You can also e-mail us a question.\r\n\r\nTo find your Xerox Support line locate the contact button at the bottom right of the Screen.", 'Hold down Shift while clicking to open this link in a new window', '(Click here)', 0)); Please contact your local Xerox Help Line arrange a service or further assistance over the phone. You can also e-mail us a question.
    Jan 08, 2009 | Xerox WorkCentre M20i All-In-One Laser...
    Sanyo PRO-700 Cellular Phone Logo
    79 people viewed this question
    Top Sanyo Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Jeffrey Thomas
    Jeffrey Thomas
    Level 1 Expert
    rey francis basa
    rey francis basa
    Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
