Question about Canon PIXMA MP160 All-In-One Printer
My Pixma mp160 will not feed paper into the feeder. An E3 comes up on the screen but there is no paper stuck in it.
  • 4,041 Answers
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Paper jammed under roller small piece of paper keep saying jam e3
Good day, I will give you the procedure how to clean the roller or canon pixma mp160.
Procedure:
1. Press [On/Off] to turn on the machine, then remove any paper from the auto sheet feeder.
2. press [maintenance] repeatedly until <b> appears.
3. press [black] or [color].
4. repeat steps 2 to 3 twice.
5. open the paper output tray.
6. load 3 or more A4 or letter-sized paper in the auto sheet feeder.
7. repeat steps 2 to 3 times.
the sheet paper is automatically fed in and then out of the machine.
have a nice day.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My all in one has an error message
E3 is a paper jam they may be small bit paper jam in side
Jan 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Printer will not feed paper and displays error code E3... have tried cleaning the feed mechanism as per the owners manual but problem persists
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-20
Aug 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E3 code error mssg on printer MP160
As you will probably know E 3 on Pixma is paper jam.
Double check that there is no paper inside, and turn printer upside down shaking it a bit to check if there is any small foreign object (screws, pins, coins etc.) stuck inside.
When there is no jam in the paper path, this problem is typically caused by a broken part in the paper feed mechanism, in the page unit.
The paper feeding mechanism has two white plastic gears connected together with a central spring, near to the waste ink tank, at the bottom of the printer.
This are quite delicate, they often get stuck or boken, or you lose the spring, and the printer stays stuck with E3 error.
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
E3 Error
Aug 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 on Pixma MP160
Looks like there is something stuck in the insides of the printer preventing it from running to one side. A small paper clip, Ball pin etc., can cause this. You might have to take it apart and look for it. I had fixed a similar problem recently and the stuck object is "HAIR BALL!"
Jun 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Pixma mp160 error message
Ok, my machine was also showing E3, and would NOT go away. My solution: turn the machine off, feed a piece of thick cardstock into the paper feed.Turn the machine on, let the machine take the paper almost all the way in, then pull it back all the way out against the feed. My E3 disappeared and has not yet returned!! Hope this helps David
Nov 26, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One Printer Logo
old marine
old marine
