Question about Sony PlayStation 2 (PS2) Console
I think my lazer is broke cause i dont see a light and the spindel does not spin. help!
  • 456 Answers
Check where the laser plugs in to the mother board and that the cables and plugs arent damaged, and if they are ok, you may need a new laser. Good luck.
Posted on Nov 16, 2009
The CD player will play some purchased CD-s but will not play others. The ones that it will not play do NOT iniate the disc motor but a click is heard and the display reads NO DISC. I have cleaned the...
If you can disassemble the CAP(disc holder) and place it on the disc while it is on the spindle and at the same time push the (hidden)lid switch you will see the lazer"s lens move up and down while trying to focus on the disc. If the lazer see's the disk it will tell the motor to turn. If it dosn't see the disc it will not turn the motor. Some model will kick the disc to spin a little while trying to see the disc. This type of player can be tricked into seeing the disc if you spin the disc a little by hand when the lazer's lens is moving up and down. At that point in time it might see the disc and take over the motor and spin up to normal speed. If the disc is an illeagal copy sold as a original the quality of the disc could be the cause. If the player is very clean (no small hairs stuck to the glue that holds the lens in place) (never clean with a cotton swab, use a shammie swab with rubbing alcohol or isopropal 99%) the problem could also be that the lazer is just not strong enough and the whole lazer-motor assemble should be replaced. Older units could use 1 drop of light motor oil on the motor shaft at the bearing to help start the motor when the system kicks the disc to spin. If the player reads the disc at the time you manually spin the disc maybe a good cleaning and oiling is all that is needed. The disc spins clockwise. if the disk spins counter clockwise replace the whole assemble. Maybe simpler, just give the disc a good clockwise spin and quickly close the door and push play while the disc is still spinning. if it starts, there you go. Don't use caned air on the lazer assemble. it will blow the dirt further into the lazer mechanism under the lens and make matters worse! Good luck!!
Oct 29, 2010 | Sony CFD-G50 Cassette/CD Boombox
I have a wireless lazer mouse and key board, the mouse all of a sudden started acting eratic and the red lazer light had gone off. I tried troble shotting but it came back an said that everthing was...
common causes; -dirty optics, clean red light area with canned air. -polished or shiny desk surface. optical mice dont like shinny surfaces. try a piece of paper under the mouse to see you need a mouse pad. - batteries low. even though they have some charge, low batteries can cause erratic behavior. as the mouse and base connect then fail, then connect, then fail. ect. often people dont realize how fast optical mice eat up batteries. check the wire to the base, sometimes these get caught in sliding keyboard drawers and get damaged. hard to see untill you inspect the whole wire( to the base anyway). Animals sometimes chew em up too. :) if any of the above help you. please provide some thumbs up. Cheers
Aug 26, 2010 | Logitech 9311570403 Mouse
Ps3 wont work after mgs4
if you see a red light at startup then you might need to format your hdd and reinstall the latest firmware.
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
Disc is spinning and not reading
what player do you have.
it can be the lazer thats dirty or the main board thats not taking in the info.
open the player.(remove the casing)
switch the player on
open the tray and then close it.(don't put a disc in.)
see if there is a red light shining at the lens.
if you see no red light your lazer is faulty.
if you do see a red light just take a cotton **** en gently rub it over the lens.
please email me at "ruanelectronics@gmail.com"
for more help
May 11, 2009 | Televison & Video
Wii keeps freezing plz plz plz help realy plz crying
Try geting a lazer cleaning kit to clean the lazer cuase it might have dust on it making the games freeze
Jan 10, 2009 | Nintendo Wii Console
Washing machine doesn't spin spindel
whirpool part# 80040 agitator dogs need replacing remove center cap remove bolt in agitator pull top section up ..may need to hold bottom down and pull up sharply on top section to separate
Nov 06, 2008 | Roper RAS6233KQ Top Load Washer
Singer 7442 will not sew
Had the same problem as mommyb2 - it was the bobbin spindel was in the wrong position. Push bobbin spindel to the left and it works for sewing.
Have the same problem winding my first bobbin - pushed spindel to the right to engage bobbin fuction and the machine locks up and wont wind the bobbin. Irig did you bring it in for repair? I'm thinking its broke - which **** as mine is a brand new machine
Mar 23, 2008 | Singer 7442 Mechanical Sewing Machine
Psp trouble
I think the back of the lazer assembley might have come loose or off. It happened on my old psp. Every time it would load, a flickering red dot would appear. I dont think you can gat the back of the lazer assembley, but the lazer assembley itself can be bought for a reletively low price on eBay. Pretty easy to replace too. 4 screws and 2 cables.
Feb 20, 2008 | Sony PlayStation Portable (PSP) Console
Dvd player reading no disc error
where you say u have cleaned the lens have you been in side it, if so does the dvd spin round when you put a disc in, if it does and it doesnt read try a cd in it if it reads that then it will be the lazer, if it doesnt read it it could still be the lazer but could be a few other things like spin motor.
hope this helps
Feb 09, 2008 | Durabrand DUR-1700 Portable DVD Player
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
