Question about Symantec Norton 360 Full Version for PC (11022527)
My computer doesn/t hav eNorton, though I paid for it, but I switched from an old desktop to a new laptop.
  • 4,806 Answers
Do you mean you want Norton on your laptop?
If so then go here to symantec and contact them. I'm sure they will provide you with a link to download the program and give you a key to activate it seeing as you have already paid for it.
Make sure you have all your details ready as any support technician will ask for proof of purchase.
http://www.symantec.com/support/index.jsp
Regards.
Posted on Nov 16, 2009
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
D945ghz
Intel D945GZ motherboard? Got it. Now what the world are you talking about? A Chassis Intrusion Switch? What desktop computer is it in? Computer manufacturer name, and Model Number. Post back in a Comment.
Wait a minute. Won't boot, or the Power Supply doesn't start up?
Power Supply doesn't start up;
1) You have a bad ATX power on switch
2) You didn't connect the ATX power on switch to the correct pins, on the Front Panel header.
3) You have a bad Power Supply
http://www.directron.com/atxswitch.html
Computer doesn't boot up;
1) You didn't follow Anti-Static Precautions
2) You didn't apply Thermal Paste to the top of the Processor, before you put the Heatsink on.
3) You didn't connect the 4-pin ATX +12 Volt power cable.
Power for the Processor. (No processor, no computer)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
4) You didn't use the Installation Disk (CD) that came with the motherboard. (Has the DRIVERS)
5) Is this a replacement motherboard for a bad one?
SAME motherboard, or a different one?
Why?
Because when Windows is installed on a computer, (Harddrive, actually), it assigns hash values to certain major hardware components.
Components such as;
1) Processor
2) Motherboard chipset
3) BIOS program, version, and date
4) Harddrive
5) Graphics chipset. (Whether Integrated Graphics, or a graphics card)
Change any two of these components, and Windows will think it is being stolen.
Microsoft User's License states, "ONE Genuine copy of Windows per ONE computer "
[ Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer ]
If you are lucky, the Windows activation screen may come up. Windows will want to be activated again. (Activated, not Registered)
Doesn't happen all the time, though.
Using a brand new genuine copy of Windows? Make sure you go into BIOS Setup, and in Boot Order, set the first boot device to CDROM.
The LED light on the motherboard indicates it HAS power.
Motherboard Manual for the Intel D945GCZ mobo. (MOtherBOard),
(GHz stands for GigaHertz.
Giga = approximately 1 Billion.
Hertz stands for Cycles per Second.
1GHz = approximately 1 Billion Cycles per Second.
It refers to Frequency Rate. For laymen frequency rate = 'Speed')
Plus, it isn't new. It is NOS. New Old Stock.
Means it could be a bad motherboard, even if it has never been used.
{Computer technology follows Moore's Law,
http://en.wikipedia.org/wiki/Moore%27s_law
What is new technology today may be old tomorrow }
http://www.intel.com/support/motherboards/desktop/d945gcz/sb/CS-020793.htm
Blue -> English Product Guide [PDF]
Let me know if you think there is a Chassis Intrusion Switch.
It will operate one of two ways;
1) When the cover is removed, the switch is open. No connection of the two wires is present. Remove the switch, put a piece of heat shrink tubing over one wire, and slide it back out of the way.
Twist the two wires together with an Electrician's knot, solder them, slide the heat shrink tubing over the connection, use heat to shrink the heat shrink tubing.
2) When the cover is removed, the switch is closed. The wires are grounded out. Remove the switch. Cut the exposed bare wire off, leaving just the insulation. Put a wire nut on it. Do the same for the other wire.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 24, 2012 | Intel Computers & Internet
Computer not powering on. green light is on behind tower though. what can it be?
Could possibly be your power supply. unplug the computer and take out the ram and put them back in. If that doesn't work, get a new power supply.
Mar 22, 2012 | HP Compaq Presario SR5350F Desktop PC...
Can't plug in power on button cable to new motherboard
Look closely at the new MOboard silk screened lettering to find where the power button wires and the leds go. They're there, just might be in a different place.
May 09, 2017 | Acer Aspire AM1610-U1201A PC Desktop
I have an old desktop Presario 4409C that I used for years, and it got rather quirky toward "the end". The computer would not boot up, as though there were no power to the desktop at all. I...
Just because it came with 7 doesn't mean you couldn't go backwards and install XP.... or you could create a 2nd partition and dual boot. You'll get a faster and more reliable machine to use your new tool with.
Aug 04, 2011 | HP Compaq Presario SR2011WM PC Desktop
Can't switch paid Norton Antivirus to new computer
Call: 1 (866) 200-0892
In Canada Call: 1 (866) 200-0794
Jan 18, 2009 | Symantec Norton AntiVirus 2008: Windows
Can't switch current paid product on new computer
My personal opinion on this is that you are unlikely to be able to move the account; given the problems I have had with norton in the past, I wouldn't try; but would instead use the free or Home editions of Avast! or AVG Antivirus.
Printer
Well you mite hav a problom with your CD or if your PC\laptop may be too old or your USB cord may be bad and if you hav a worenty get a new CD
Apr 05, 2008 | HP DeskJet F380 All-In-One Printer
Symantec Norton 360 Full Version for PC (11022527) Logo
Top Symantec Computers & Internet Experts
Lisa
Lisa
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
