Question about Husqvarna Huskylock Computerized 910
I am trying to use the two-thread converter, but are unsure as to where to place the threads. The manual has no illustration showing the converter and threads. Any assistance would be great.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
If you know how to install the converter, the rest will take care of itself. Thread the lower looper as you normally would. When you rotate the handwheel through a revolution you should see the upper looper pick up the lower looper thread where the converter meets it. It will then be carried up to the needles.
Posted on Feb 16, 2010
I have a Janome 1110DX serger, how do I thread it when the spacer has been inserted to do a 2 thread hem.
Need more information to answer this question. "Spacer inserted"??? You mean "Double Needle"? for a 2 thread hem?
Cheers,
Embroidery Services
San Diego, CA
Jun 15, 2016 | Janome Sewing Machines
Borrow sewing machine from sister unsure how to thread it correctly and when i do the thread fromthe needle keeps breaking when i try to sew its a brother XL-5130 sewing machine and i know nothing on how...
you need to go to this webpage http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/doc/manual_index.html?reg=us&c=us_ot&lang=en&prod=hf_xl5130eus&dlid=&flang=English&type2=-1 and download the instruction manual for this model. It has the threading up instructions plus selecting stitches, winding a bobbin etc.
The thread breaking is most likely due to incorrect threading up of the top thread. I suggest that if you can, you print out the manual, put into a little folder and place beside the machine and refer to it often. Follow the instructions in it on winding a bobbin, putting it into the bobbin case correctly and threading up the top thread. Make sure the bobbin goes into the case the correct way, as per image.
Remember, ALWAYS THREAD UP TOP THREAD WITH THE PRESSURE FOOT RAISED, this keeps the tension discs open so the thread can seat into the tension device correctly. And you must get the bobbin thread into the tension spring fully and then place the bobbin case into the shuttle using the little latch so it stays in place.
Also, new needle for every new project, and put the needle in "flat shank to the back". It will take standard domestic sewing machine needles 705/130H but it is important to select the correct sized needle for the fabric you are sewing so that the needle can penetrate the fabric but not leave big holes. So for light weights like chiffon you want a size 60 or 70. For medium weights a size 80 and for heavy fabric like denim or a coat weight wool you would use size 100. Ball points for stretch fabrics so that the needle pushes between the fibres and a regular point for woven fabrics.
I trust this helps you out, 4 thumbs up if so. Thank you.
Jun 28, 2011 | Brother XL-5130 Mechanical Sewing Machine
I have a white model 999 but am unsure how to thread it I am trying to find a visual online
Do you have a manual?
You can get a free download manual for your machine from the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in w999 and click on search.
On the next page click on free download!
The manual will show you how to thread the machine correctly.
Hope this helps!
Nov 15, 2010 | White Sewing Sewing Machines
The tread gets all bunched up on the underside of
Take the thread off the top of your machine and rethread it. Anytime a sewing machine bunches up the thread on the bottom the cause is the top thread. Make sure the tension dial is on "5". After you thread the machine, put the pressure foot down,(like its resting on fabric, but not on the thread), and pull the thread towards the back of the machine. It should be somewhat tight. The needle should "bow" slightly before the thread comes through the needle.
Oct 06, 2009 | Sewing Machines
Threading illustrations too small
You might take a look on ebay item 160362974035
May 29, 2009 | Baby Lock Eclipse Serger
How do I keep bobbing thread from bunching on model 375?
upper part of machine not threaded correctly - no needle tension = bunching underneath
Apr 22, 2009 | Euro-Pro 373 Mechanical Sewing Machine
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Bottom thread loops
More than likely the Bobbin is not threaded correctly and the tension is not being controlled.  review the manual carefully, pay attention to the direction the thread is wound on the bobbin and place it in the case exactly as illustrated, feed the thread through the tension groove.
I would also advise returning to the bobbin to the factory setting and leave it there.
Jan 01, 2009 | Singer 3116 Simple
Threading CG-590
I have a CG590 SEWING MACHINE AND CAN NOT THREAD IT WITH THE DIRECTIONS THAT CAME WITH IT. CAN YOU HELP THANK YOU, SANDY
Sep 21, 2007 | Sewing Machines
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
