Question about Garden
I'm trying to locate a walbro hda 26b carb or parts other than gaskets i need the shaft that connects to the throttle cable and to a flapper in the carb or a replacement carb new or used is fine. or a current cross reference to a current bolt on carb my red max blower is an eb 430 purchased in 1989 so i don't want to put too much money into it
  • 486 Answers
Redzaw.walbro carb.21-246 fuel line routing
HDA 246 has either a separate primer or one that is built into the carb. Which one do you have?
Aug 31, 2014 | Garden
Walbro carburetor diagrams
must be a small tiller to have a walbro carb on it most of these have a hole drilled in throttle cam ("D" looking thing on top) that the cable has a "L " hook that goes into it cable clamp must me loosed to allow a 45 degree entry of "L" hook into "D" plate
Jul 23, 2014 | Craftsman Garden
Toro briggs OHV runs too fast
throttle spring could be broken stretched or missing
Nov 14, 2012 | Toro Lawn Mower With Toro Power Tools
I am looking for Ryobi brush cutter parts
Any local small engine service shop should have these parts in stock. Its called a 'primer bulb'.
Determine if the primer bulb is part of the carb or sperate from the carb with fuel lines connecting them. If seperate remember how the 2 lines get connected when you remove the bulb and replace with a new one. If a part of the carb...
You need to determine if the carb is a Zama or Walbro. It will have the name stamped on the carb. All Zama carbs use the same bulb. Walbro has a small and large bulb.
It would be worth while to install a new carb kit while you have the carb off and apart
Nov 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
Three (3) possible carbs were available on your machine.
If you have:
Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
If you have:
ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
If you have:
ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
Hope this helps.
Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Starts and idles but dies when i pull the throttle.
Either clogged or needs cleaning/ rebuild. ITS SIMPLE! ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Jul 06, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Engine will not throttle up
the red and white screws are the air and fuel mixture needles they may need adjustment if you are getting plenty of fuel to the carb. note that newer walbro carbs these mix set screws can only be adjuted very little. they will break if you twist to much. but firt when you took the carb apart was the fuel metering diaphram crisp or was it still flexable? ( black gasket thing under side cover . it has a small metal botton in the middle of it. if this does not flex freely then you need a walbro carb gasket set. mabe 5 to 10 bucks.
Jun 08, 2009 | Ryobi Garden
Parts number
You need to know if it is a walbro or a zama carb. to start with.
then look closely at the carb. and find #`s
very small
walbro will be wt or wa then some #`s
zama will be c1q or c1u and some #`s on the opposite side of carb.
Walbro will be on the same side
you need to know the carb. #`s so a kit can be found for that particular carb. IE: complete kit or diaphram kit
May 20, 2009 | Homelite Consumer Products MightyLite...
Echo cs8000
The solution to the fuel starvation problem with the Echo 8000 is based on the metering diaphragm. In late 2007, Walbro sold off a huge amount of carb kits which were not ethanol compliant. These kits were purchased by resellers like Stens. Now that many states have ethanol blended gasoline, the metering diaphragm dissolves and hardens in the presence of the added ethanol. You will need the walbro carb kit with a 'new' metering diaphragm that is not sensitive to alcohol or mtbe which is the summer fuel additive also in alot of areas. Each kit comes with a date on the package, use Walbro K22-HDA manufactured after 06-2008. I run these saws that is how I know.
Sep 24, 2008 | Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
