Question about Whirlpool LER4634J Electric Dryer
Model #len1000pqo does not heat enough
  • 77 Answers
Hi,check your vent to make sure its clear all the way out the house then take your lint trap and scrub it clean with a brush.Hope it helps.
Posted on Nov 16, 2009
Asko D5457 DISHWASHER. Dishes are clean but not dry.. Especially plastics on top eack despite long dry selected. Any ideas as to what may be occurring?
Unfortunately, plastic will not dry well if at all in this model. The only heat for drying is the residual heat left in the dishware after the hot rinse cycle. Plastics do not have enough thermal mass to hold on to the heat long enough to dry. Also, you MUST use a rinse agent in this washer. Those detergent packets with rinse aid in it is not enough. Make sure to keep the rinse aid dispenser full.
Jul 01, 2016 | Asko Dishwashers
Why does this thing not run continuously and stay on long enough to heat up a room?
I would guess the over heat sensor has failed .contact the manufacturer customer support
Jan 25, 2016 | Windchaser Heating & Cooling
Remove and replace heating element in GE Dryer
Not enough info! what is model number?
GE dryers has many models and each one has different procedure to remove heating element
Apr 20, 2014 | GE Washing Machines
Toastmaster model 265 user manual
Indicator light shows the the heating element is on. Yes, it should be hot enough when the light goes off. The numbers at the following site may not match but you should be able to find the information that you need.
Feb 18, 2014 | Toastmaster Kitchen Appliances - Others
Heater not heating enough
Electric furnaces have strip heat inside of them. Depending on the model, size, etc, is how much heat the system can provide. Many times, if the system has worked in the past and started to have problems later, it's because you have lost half or more of your heat strips. They come in different sizes, 10kw, 15kw, 20kw, but ran on different contactors. So if you have a tripped breaker, faulty heat sequencer, etc, you can still have heat, but not the full amount. I strongly suggest any electrical related problems be look at by a qualified technician when dealing with air handlers. Hope this helps!
Dec 08, 2013 | Heating & Cooling
How to increase temperature on model BCM120. The coffee is not hot enough after brewing. Is it possible to increase the temperature on the thermostat.
There is no temperature adjustment for the heating element under the carafe.
The Instruction Manual says:
If coffee is too cold, machine not preheated, cups not preheated, milk not heated enough (if making a cappuccino or latté)
Jun 12, 2011 | Breville Coffee Makers & Espresso Machines
Kenmore gas dryer does not get hot enough. Gas burner does not seem to stay on long enough. Model 110.72912100
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 21, 2010 | Kenmore Dryers
Not enough heat to dry clothes
You may find that they come as a kit, as I had one similar a long time ago.
Mar 13, 2010 | Dryers
Crosley Dryer Model CEDX463RQ1 no heat
take elements to a dealer and have them checked, unless you have a digital multimeter and can DIY.Otherwise get a replacement element
Aug 01, 2009 | Dryers
HEATER ISNT HEATING UP THE ROOM ENOUGH
It sounds like the space is too large for the BTU capacity output of the unit.
Did the unit ever heat the space?
Have you measured the temperature of the incoming air, vs the discharged air?
And finally, based on the Model number in the heading of this thread, this unit is cooling only, no heating (it's not a heat pump).
Jan 11, 2009 | GE AJCQ08ACB Air Conditioner
Whirlpool LER4634J Electric Dryer Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
