Question about Coleman Mach III Air Conditioner
The fan comes on, but air compressor wants to start but won't. Funny smell. Thanks Mike
It is likely the capacitor is faulty, when they go they usually heat up and burn hence the bad smell. If your unable to test the capacitor you can try replacing it with new. The capacitor at the compressor should state its value in micro farrads and a rating in voltage.
Posted on Nov 16, 2009
Testimonial: "I thought that was the problem, thanks for the feed back. Two heads are always better than one. Thanks again. Mike"
Ac fan works relay comes on but compressor won't start
Sounds to me that the compressor start capacitor is the first thing I would check. You will need to get on the top of your camper and remove the outer cover. The capacitor is the part that stores up enough energy to kick start the compressor when it starts. Sometimes a capacitor will swell if bad, but not always. Mark your wiring before removal and have someone test the capacitor to see if it needs replaced. I will be here should you have any questions. If helpful please rate this solution, Thanks Sea Breeze
Here is a link to Dometic Service Manuals Click=> HERE
comparison_good_and_bad_round_capacitors
Nov 02, 2011 | Dometic Rooftop RV Air Conditioner
The AC unit turns on and I can cycle through the options in order to adjust the fan speed however the fan does not start in any of the three settings. The ac unit produces cold air, however the fan does...
You say the unit produces cold air ??? where are you getting the cold air from???
If your fan does not run in any speed F1, F2 F3. and a funny smell sounds like the motor is bad
Mine works in F2, F3 but not in F1
Apr 12, 2011 | Kenmore 75085 Air Conditioner
Has a funny smell when its on vie cleaned it and
The problem is that you have a leaking compressor or a leaking pipe on the device, because the odour is the odour of freon inside the compressor, which indicate you have a leaking compressor or pipe somewhere around the unit.
You will need to trace the copper pipe to see if there is any leakage on the pipe, if none, then the compressor is the problem, you will need to replace the compressor on the unit.
Take care.
Jul 07, 2010 | Maytag Chassis Built-In Air Conditioner...
Aircon works fine for 5 min after starting car then funny smell and nothing but warm air. when revs kept low might come on again for few min
Check the compressor when you notice the smell. See if its running or not. It could also be the blower motor itself. I'd suggest checking the blower motor first off. Those usually only last a few years, and if it got wet some how it could have rusted or corroded on the inside. Or a wire broke on the inside and it shorts out to ground which could explain the smell.
Jul 15, 2009 | 2001 Saab 9-3
Kelvinator Inox Freezer not switching off
hi! theres no funny when you smell burning please switch off the power and you che
Jan 20, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
True cooler made a pop sound and was a bad odor thereafter
Sounds like the compressor may be going off on overload. The start parts for the compressor may need replacement. Tell me the numbers on the compressor and I can come up with a universal replacement part! ;)
Nov 22, 2008 | True G4SM-23 Refrigerator
Hard Starting Dometic Rooftop AC unit
Just add a$10:00 hard start kit to the compressor.
Sep 06, 2008 | Dometic Rooftop RV Air Conditioner
Compressor stops suddenly....and then starts again
most condenser units have a fan capacitor and a compressor capacitor and some combine it into one,take your cover off and look to see what you have,i'am thinking it the all in one and it should be replaced,let me know-mike
Jul 03, 2008 | Ruud UAKA042 Air Conditioner
Coleman Mach III Air Conditioner Logo
258 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
