I have a LG front loader washing machine WD-1049C. It is stuck on 1min left of cycle & even when I turn off & left over night, still 1 min when restart so can't use. Can I 'reboot'?
    President:
  • 1,865 Answers
Powering the unit down and back up is the reboot process. Your main control board has failed, and needs replace/repair
Posted on Nov 16, 2009
I have a LG front loader WD-1049C it's 6 yrs old And has just started to make a loud noise while in spin cycle All other cycles are fine
If the washer is making a loud noise the tub bearing might need to be replaced. This is a very involved repair and will require disassembling most of the washer. The manufacturer recommends that if possible the complete outer tub and bearing be replaced rather than attempting to replace just the bearing in the tub. If the bearing is bad the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine
Feb 19, 2015 | LG Washing Machines
Why does my LG WD-1049C washing machine get stuck when doing a wash cycle?
first thing to check is the carbon brushes,cheapest fix too.they wear down after a time and need to be replaced,check see if they are worn out
Mar 12, 2013 | Washing Machines
Where is the lint collector on LG 7.5g model WD 1049C Front Loader washing machine.
The combo washer/dryer doesn't have a lint collector. Air is circulated through a condensate tube and is washed down during each drying cycle.
Jun 16, 2011 | Washing Machines
I have a LG WD - 1049C front loader washing machine showing the DE error have emptied out the washing machine and it still comes up, partner bought a new door latch and installed it but the DE is still...
DE error does mean the door latch,but there are three parts that could cause the error code.If you have changed the door lock already then the main p.c.b/computer board has failed and not registering the door lock but there is a 5-10% chance it's the wiring connecting the two parts together.So basically you need to change the main p.c.b & if that doesn't work it needs to be rewired.unless you know how to use a multi-meter then you could test the wiring for a definate answer.THANKS ECO KIZZA
Feb 18, 2011 | LG WD-1045FH Front Load Washer
Hi. My LG 7.5kg Front Loader Washing Machine WD-1049C does not spin. It washes the clothes ok but fails to go into the spin cycle. The fault code UE comes up if i let it bumble through the cycle long...
Im soory to have to tell you this but i belive it is mostlikley the motor control board and it is worth a couple hundred dollars plus lobour it is the board benith the durm in the front right corner i hope im wrong on this i bet your clother are stuck in there with the door locked full of water there is a trick to draim then unlock the door by pushing in 2 buttons at the some time but i cant think of it right now ill try to post that trick if i recall it latter hope this helped
Aug 20, 2010 | LG WM-12230FB Front Load Washer
LG WD-1049C Front Load Washing Machine Pump impeller sloppy
probably better change the pump if you feel any up and down slack in the impellor. you may have an ingress of water through the seal.
Mar 13, 2009 | LG WD-1045FH Front Load Washer
Error display "CL" - what to do?
THe child lock is on. Mine came on for some random reason. On my LG front loader there is a button on the right hand side with a cartoony picture of a child and a padlock. Press this.
Jul 04, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
