Question about Bowflex Treadclimber
I have a TC5000 When I am walking for about 5 to 15 min. It stops. and when I pull the safty pin out and put it back in its ok for about the same time and quits again.
    New Friend:
  • 64 Answers
Check to make sure steps are being counted. This tells the machine someone is using it. The step counter is in the center of the steps on most machine. It will sometime count intermittenly. Another thing to check is if the machine seems to be laboring more when you start to walk on it. This could be a sign that it needs lubricating. Check manual for lubricating proceedures.
Posted on Nov 18, 2009
Have a oldsmobile alero that over heats every 5 to 10 mins, always have to pull over. Thinking there might be a pin hole in hoses that enlarge under pressure, do not see any coolant leak at all. Think
Might be the thermostat or could be a cracked head! Check your oil for water! And you can buy some stop leak from like auto zone or other parts house
Jan 14, 2013 | Cars & Trucks
1987 Toyota Camry, auto, 4 cyl. I thought I was low on gas (since had fuel light on)...car would not start. Walked home (20 mins) came back and added fuel (1 gal), started and drove to gas station - filled...
theres a couple of things to check for this first generation series,, check the Air flow meter connector FP terminals, and intake tube, make sure its tight and doesnt have a leak.
May 31, 2011 | 1987 Toyota Camry
I PROPPED UP MY PRO FORM XP CROSSWALK 580 TREADMILL TO CLEAN UNDERNEATH AND I CAN NOT FIGURE OUT HOW TO LOWER IT?
There is a knob about halfway down or up, depending on how you are looking at it. You need to lift up or push up a little bit to take the weight off the locking pin, as soon as the weight is of it should pull out about 1/2 of and inch. Be careful ALL the weight of the walk deck is now in your hands. Be prepared to lower it, and use your second hand immediatly anfter you pull the locking pin out. After the walk platform starts to come down, let go of the locking pin, it has a spring to pull it back, but the pin only fits in ONE hole in the prop rod, so it wont grab on the way down. Some treadmills have a dampening shock to allow the lowering of the walk deck slowly, and some do not. So again BE CAREFULL, this could hurt you if it falls on you.
Hope this was helpfull
Nov 10, 2010 | Proform Crosswalk 500 Treadmill
Timeing pull cord rip out of hand when trying to start mower model 18m
what you have done is sheared the flywheel pin top of eng pull fly wheel you will find a schered pin go to lawnmower shop possible with pin get replacement just a few dollars you be back in timing and back to work let me know if you need a walk thru sparks
Apr 22, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Have a 4.9 treadmill and cant get it to adjust if i loosen bolts in back it slips if i tighten bolts on motor it quits pulling when i put weight on it can you help
Ok I really need more info but let's take a stab at it. The bolts in the back of the rear roller adjust the belt right and left. It also tightens and loosens. Ok there is also a drive belt from the motor that needs to be tight. Generally you should be able to twist the drive belt about 45 degrees. If it's more than that it probably needs to be tightened. If this is loose it will affect the walking belt the same as the walking belt being loose. So when your walking belt is slipping, make sure you tightened the right belt. Tightening the wrong belt can lead to other problems. Tightening the walk belt with the rear roller- turn both bolts clockwise equally to tighten. Remember the walking belt will travel to side with least tension. So to center belt, adj left or right side to fine tune. If belts are adjusted properly and machine stops when you walk on it, you have other issues. Could be the deck ( the board under the belt) and belt or the motor.
Nov 17, 2009 | Proform 6.5q Treadmill Walking Belt
Suddenly no compression on Toro walk behind
yes the shear pin will throw the timing off.check it anyway it might be ok but then again you ever know.check for fire coil should be at 010.from frywheel it might slip check compresstion anyway with gauge then valve gap need manual for this if ohv check pushrods this could make bad compresstion if one is bent.let me know want you find out ok
Jul 24, 2009 | Garden
Door locks stopped working, also lights do not work
ok first, the radio, if you pull radio out and remove the 10 amp fuse in the back of the radio for a few min it will reset the radio, then is "check" comes back on you need a new radio. now for the rest , it seems as though you have blown a fuse, there is a fuse panel under driverside dash. ignore what the panel says the fuses are for just look at or test them all and replace any bad fuses. another fuse block is near battery in engine compartment , check all of them to. this should fix it. if it doesn't let me know and i'll help walk you through any other testing needed. good luck.
Jul 07, 2009 | 2003 Dodge Durango
Timing belt walks off
Quite often it is recommended that you change the timing belt tensioner and idler roller when you do this job. This engine has one of each. I suspect either one of these is bad, or when you removed what I like to call: "the hand grenade tensioner", it did not get re-mounted to the block correctly. This tensioner is that little nitrogen and oil filled cylinder that you have to put in a vice and slowly squeeze the pushrod back in, and then, you put a hardened steel pin back in it until the belt is all on correctly before you pull the pin. Not saying you, but some people try and re-mount this thing without compressing it and that can lead to problems.
Mar 14, 2009 | 2003 Kia Optima
Excavator track needs to be put back on
after the idler is pushed all the way back into the frame.try to put some wood blocks under the track to remove all the slack.use the bucket to push as much of the bottom section under the bottom rollers.use a heavy chain and pull up and over the top of the roller.when you get close you can use the drive to walk it the rest of the way.if it still doesnt go you may have to break the track at the master pin. this is usually marked with a small hole drilled in the end of the pin.heat and beat the pin out,break the track.pull track over top rollers and make ends meet on top of the srocket.use a chainfall to pull two halfs together and line them up.drive pin back in and your all set.
Mar 01, 2009 | Gladiator Gear Track Pack
UNBALANCED WASHER
Does it happen all the time, with no connection to laundry quantity? In case of a positive answer, it sound like a shock absorber issue. Could be that it's moved from its place or become malfunction and should be replaced. Good luck
Aug 07, 2007 | Roper RAS8445KQ Top Load Washer
Bowflex Treadclimber Logo
470 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
