Question about Kenmore Oasis HE 27082 Top Load Washer
I have a kenmore elite oasis he. How can it set it to do a spin cycle only?
  • 4 Answers
Easy !!!! For a "Spin Only" cycle, just push Power, then push the Rinse/ Drain & Spin button near the left side of the control panel, then over on the right side of the control panel in the "Options" column you will see a little light next to the "2nd Rinse" button, push that button and the light goes out and the display will go from 20 min to 10 min.
You may want to read your owner's manual this answer is in there.
Posted on Nov 28, 2009
  • 3 Answers
Not on mine mine is rinse spin and drain..basicly another wash,,,no seprate spin...not very happy...i jumped the gun on this machine...should have gone with dials instead of the push button...
Posted on Nov 25, 2009
  • 77 Answers
There should be a "drain and spin" button.
Posted on Nov 16, 2009
4 Suggested Answers
  • 125 Answers
SOURCE: kenmore elite oasis he top loader
Is it an f code followed by a 51?
Posted on Jan 21, 2008
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
duby1990
  • 367 Answers
SOURCE: Very loud spin cycle
your bearings i the tub have gone bad. It happens usually if you use powder soap. It doesnt dissolve all the way and gets into the bearings and ruins them. Sorry but this is a pretty expensive fix. When you get it fixed used liquid soap and it shouldnt happen again.
Posted on Nov 18, 2008
Kenmore elite model 11027052602 clothes wet after spinning cycle why
You might have a restriction in the outlet hose. Worse, you might have a bad pump.
It is easy to check for the constriction. Pour water into the tub, set the timer for the spin cycle and watch how strong/fast the water leaves the hose. Check for water beneath the tub.
Oct 07, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore oasis elite dryer trouble shoot f-24 error kenmore
According to the manual, follow these steps:
  • For an "F" error on your Washing Machine.
  • Select PAUSE/CANCEL twice to cancel the cycle.
  • Select DRAIN & SPIN if there is excessive water in the washer.
  • Re-select cycle and press START.
  • If the problem remains, call for service.
Here's the full manual: Kenmore 110.45986400 Owner's Manual
Jun 15, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
Kenore Elite Oasis top loading washer wont spin during the spin cycle, but will rotate during wash and rinse cycles
Since the motor turns regadless of the direction it turns itself is good and theirfore the problem with your washer i believe is going to be the control board,it is what tells the motor what direction and what speed to turn.
GENE
Sep 23, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Nov 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
251 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
