Question about Drills
I have a DeWalt D25114K XE. When the drill is on
I have a DeWalt D25114K XE. When the drill is on hammer mode the chuck seems to spin ok but when I drill into masonry, the chuck seems to wobble. Still drills a straight hole but just concerned the chuck is damaged or i haven't fitted it properly
    President:
  • 583 Answers
Try tightening the screw down the centre of the chuck with the jaws fully open
Posted on Nov 17, 2009
Dewalt hammer drill chuck won't turn model DCD985
Make sure the speed selector lever on the top of the tool is all the way in gear, and the dial selector on the tool is in drill or hammer drill mode. If in screw mode make sure it's set to a level that it won't "clutch" out.
Feb 17, 2015 | Dewalt Drills
Why does my drill chuck seem to disconnect from the motor?
from pos 32 gear and the drive shaft on the armature can be worm out. or something was broken else.
Detail
Jul 23, 2014 | Dewalt DW505K 1/2" Hammer Drill
The chuck on my old dewalt reversing drill unscrews itself from the drill body when used in reverse mode.
You are more than likely missing the chuck retaining screw. If you give me the model number I will get you a part number and info on how to order. It is a left hand screw.
May 03, 2011 | Dewalt 12 Chuck and Key
How do I remove the chuck on my dewalt 18 volt xrp hammer drill
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting. Remove the battery! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you, and if not, explain what is happening.
Nov 28, 2010 | Dewalt Drills
The chuck on my Dewalt 18v hammer drill will not stay tight. it loosens whether I am in forward or reverse
the chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
Oct 14, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How to remove the chuck from a dewalt cordless hammer drill?
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Sep 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Remove c keyless chuck from 18v dewalt drill
There is no loctite on the chuck threads, only blue loctite on the reverse screw. This is how I remove chucks.
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck). Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Jun 15, 2010 | Dewalt 18v Battery Hammer Drill Dcd950...
How do I fit drill in this machine please? DEWALT D25113K D25113 3 MODE SDS
Youcan only use standard drill bits with the use of a chuck attachment with the SDS type bayonet. These hammer drills use an SDS type drill bit which just pushes into the fitted chuck and are released by pulling back on the lock mechanism on the chuck.
Jan 19, 2010 | Dewalt D25213k D-handle Tri-mode Sds+...
I have a DCD940KX 18v Dewalt drill driver with the one click drill chuck. It does not keep drill bits or screwdriver bits from spinning. They spin with the slightest bit of pressure on them. My questions...
this is not a common problem with dewalt. I have been using them in my construction business for years and only heard of this once or twice. I would go to their web site and get the number for their customer service. They stand behind their products and im sure they will help in every way they can to repair the drill
Nov 26, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
220 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
