Question about BenQ FP71E 17" LCD Monitor
My monitor turns white when i turn it on every
When I turn on my computer the screen is all white on my KDS monitor. I have to turn the monitor on and off about four or five times. As Im turning the monitor on and off I see some of the screen but I have to let it go completely white again and then turn it off. This I have to do about four times and then it works perfectly until the next time I turn the computer off and on again. Can anyone help me?
    Novelist:
  • 154 Answers
Your monitor is about to go out. It may be a faulty bulb if an older monitor or if a newer one which utilizes a plasma or lcd screen, the liquid crystals maybe going bad or the light source could be going bad as well. When LCD's or Plasmas start going bad, the best bet is to get a new one because to fix one is almost as expensive as purchasing a newer one.
Posted on Nov 16, 2009
Testimonial: "That sounds like what is happening, I just needed confirmation. It is an old monitor, about four years. Time for a new one I guess. Thank you"
Flickering light and screen
The power supply may be failing.
Mar 19, 2014 | KDS Computers & Internet
Iinstaled win xp, now monitor will not work. can i download and install driver onto flash drive without seeing my monitor
Turn your notebook off.
Turn your notebook on, and immediately start pressing the F8 key, once or twice per second,
until you see the Windows "start-up" menu (white text over a black background).
Choose the "start in VGA (low-resolution") mode" (or some wording similar to that).
You computer will start-up in '800-by-600-by-256-colours' mode, which should work.
Adjust the screen-resolution, and the number of colours to "optimal" values.
Jan 31, 2011 | KDS Valiant 6480iPTD Notebook
When I turn off monitor at night and turn back on in the morning I get a white screen only. After turning on and off several times and a long wait my desktop will display. What causes this problem and how...
check if your LCD monitor have bloated caps
check this site for what bloated caps look like.
http://pcmediks.blogspot.com/2010/09/samsung-syncmaster-540n-with-power-but.html
Nov 10, 2010 | KDS K22mdwb LCD Monitor
I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Jan 05, 2010 | KDS Computers & Internet
When i turn on the monitor the screen goes all white
This is usually either a problem with the controller board or the actual LCD inside the display.
You should be able to find one of these monitors with a bad power board on eBay for cheap and just replace the guts of yours with the parts (minus the power board) from the 'new' one.
It would likely be better to just buy a new one if you are out of warranty.
Sorry about that.
Jan 01, 2009 | KDS K717s 17" LCD Monitor
Sudden color distortion
this can happen if there is a poor connection of the VGA cable - tighten the screws on both ends, just in case one is loose
Dec 28, 2008 | KDS K22mdwb LCD Monitor
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
KDS monitor screen turns black
So how long have you had it, and try to blow it out. Sometime they just need cleaning. If that don't work send it back before warranty run out
Sep 27, 2017 | KDS Visual Sensations 190 (White) 19...
The white screen tells me that the display cable (inside your monitor) may be unattached or broken.
The color bands if they are vertical or horizontal lines tell me that your display cable needs to be replaced.
So overall replace your display cable. If this doesn't entirely fix the problem your logic board (inside the monitor) needs to be replaced.
Feb 21, 2008 | KDS K717s 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
609 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
