Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Computer will power up, but FPD 1730 screen stays dark, says "power saving mode" How to cure??
    Sniper:
  • 50 Answers
Its setting problem just fallow this stapes for the same.
Go to Start > Control panel > Power options Properties >
Turn off monitor: Never
Turn off hard disks: Never
System standby: Never
Apply > Ok
After that your issue will resolve.
Thanks
Abhay Singh
Posted on Nov 24, 2009
Message from display FPD 1730 won't go away
press the menu button on screen panel and press exit.
Dec 02, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
My monitor will not come on. It just states Power Saving Mode
If you are using Windows Vista this is a known issue try rebooting your PC if the monitor comes back then try to do the Windows Updates
Sep 17, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Out of Frequency error
1. Start Windows in safe mode by pressing F8 and Change the display properties to 800 x 600 16bit
2. Restart in normal mode
3. If the 800x600 screen resolution doesn't work try going into safe mode and trying a lower resolution
Jul 17, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Won't come out of power saving mode
chek the connection cable between the CU and the Monitor and the power supply cable of the montor or give another outlet
Aug 16, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
No Power On at all
What it sounds like is the Power supply on your FPD is bad. If its making a High Pitch Sound, A circuit or piece of your power supply is failing. It would need to be replaced in order to get it working.
Suggestion.
You can repair this easily if you have another FPD 1730 lying around that doesnt work you can replace parts, but its best if they were made around the same time because certain models have 3 boards(video board, inverter, power supply) But most have two boards (power supply, video card)
They are easy to replace and maneuver if you want to give it a try. Open the FPD and see what kind you have. If anything you might be able to find a part online.
Good Luck,
I hope this helps
victorsinferno45
Jun 07, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
Power saving mode
go to comtrol panel and change the settings in the power saving control options... everything wi be fixed without any big problem
Feb 20, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
Gateway FPD 1730 17 in. Flat... Problem
Try using it on a different computer, it's possible that it is your graphics card causing the problem. Check for bent pins.
Dec 20, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
My monitor will not stay on. Gateway FPD 1530 15 in.
problem of smps some time it happen the power supply con't give the complet supply.
if still problem then replace RAM
or replace the display card.
Nov 17, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor problem.
This just happened to me last night.  My web research indicates that the monitor is bad...others have had the exact same problem.
Oct 25, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Open Questions:
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
505 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
