Question about Gorilla Cycle Alarm, With 2-way Paging System
I have a bad shock sensor. Could i just buy a new
I have a bad shock sensor. Could i just buy a new one or do i have to replace the the whole alarm?
    Problem Solver:
  • 11 Answers
Yes I think the dei shock sensor will work part # 508D
Posted on Nov 16, 2009
I have a viper sst on my 2003 Chevrolet duramax truck, At Times The Alarm Will Start Chirping, " like someone is bumping the horn every few seconds", for no reason, why and how do I fix it?
This is a prewarn trigger from the shock sensor on the alarm.it's meant to warn a theif you have a alarm this should only go off if there is some kind of disturbance around the truck. The shock sensor is probably set to high. the shock sensor is under the dash it's a clear square box
Jan 27, 2015 | Viper Vehicle Parts & Accessories
Vr Calais 5lt.my alarm is going off for no reason at least 5times a day:(help
buy a falcon... just kidding mate. it is probably and after market alarm yes???? hard to diagnose without knowing the brand, model and features or your alarm but long story short it is well worth the cost to get a professional to install a new one. the issues you are experiencing could be due to a rookie installing an alarm, a faulty sensor, bad earth, over sensitive shock/tilt sensor, shoddy constant....the list goes on. an alarm is worth doing it right.
Jan 03, 2015 | Cars & Trucks
Sensors all going off
Scan it to see which sensor is bad.
it can only be 3 things
bad sensor (assumes door not bent in crash)
bad wires to sensor
or the alarm controller is messed up.
we check the voltage at the sensor, if wrong correct that.
if good to the alarm we replace, it,
just say a new 2014 Toyota do this and the controller was bad.
in warranty .
Jul 07, 2014 | 2005 Lincoln LS
Security system disarm
call the dealer and they will walk u through on dis arming the alarm
Jan 18, 2014 | Shock Sensor AS94904P
Does cold weather affect car alarm sensors? Help?!?
it could affect the shock sensor. it may make it less accurate and may take more of an impact to set alarm off but what i can tell you is that most good alarm systems are not affected by the weather , the cheaper brand may be affected by the cold but most no.
Dec 22, 2012 | Cars & Trucks
I have volvo s40 2000, the alarm doesn't start when the car shocked, where i can found the shock sensor???
the shock sensor is mounted under the dash and is sometimes part of alarm box or separate unit, look for module under the dash and trace wires, it separate box it is often tie wrapped of a set screw, box it 1x1 to 2x2 box usually 3 wires, often attached to steering column or metal strut
Jun 09, 2012 | 2000 Volvo S40
I have a 2011 doge avenger with stock alarm and 504k shock added. when i remote start the car the horn blows for 2-3 secs. turning off 504k stops this. help
You are having this problem because the OEM alarm will shut off your engine and trigger your alarm when the hood is opened. Your 504k sensor is connected to your hood, so when you start your car remotely, the vibration is triggering your shock sensor and thus triggering your alarm. I had this same problem. You need to reduce the sensors sensitivity dramatically to help resolve this issue.
Jul 23, 2011 | Viper 504d Double Guard Shock Sensor Car...
Alarm goes off whenever
could be a bad alarm module or shock sensor is going bad, and last a bad wire . good luck.
Oct 14, 2009 | 1999 Toyota 4Runner
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
Prestige alarm sounds off all hours of the night why please help!
The problem could possibly be that the shock sensor is too sensitive. It may need to be adjusted. You will need to find the alarm module and see if it has a built in shock sensor or if it separate. Either way adjusting the sensor will help.
Apr 10, 2009 | Prestige 2 Button Remote Security System...
Gorilla Cycle Alarm, With 2-way Paging System Logo
70 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
xxxxxx xxx
andy148814
Level 1 Expert
Rocguy
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
