Question about Motorola Mobility Karma QA1 Cell Phone
Buttons on my karma phone not working properly, especially the main toggle button, up down enter
Problems with Android OS Marshmallow. Home key does nothing, quick toggle screen won't scroll down above the notification tray, lock screen doesn't appear at any point.
If you get random errors or unstable system after an update, it's best to do a three button reset from android recovery menu. Wipe cache and delvac partitions and you should be good to go.
WARNING: this will erase all your data.
Google on how to do a reset from the android recovery for your particular model.
Mar 27, 2016 | Motorola Moto G (2nd Gen)
How to use motorola unlock code
You can use Unlocking instructions to enter the unlock code in Motorola KARMA QA1....Visit the site
Simpleunlocking.com/motorola-karma-qa1/rs16wp9/ get Unlock code and instructions ,unlock it step by step..Unlocking instructions is below:
Motorola Karma QA1 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola Karma QA1 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola Karma QA1 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola Karma QA1 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Karma QA1 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Karma QA1 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Sep 13, 2012 | Motorola Mobility Karma QA1 Cell Phone
Our office has Samsung KPDCS-12B LCD phones. How to we store and delete numbers please ?
to program the directory on a 12 button handse;
Press the TSFR key
Enter 200
Enter code 1234
=/- key to enable
Speaker key
Your next command will be the MMC required.
To program the system speed dial directory
Enter 705 - Speed dial 12th Button down to toggle between
Enter 706 - Speed Name the 2 MMC
Feb 23, 2011 | Samsung Phone PDCSLCD12B
Karma is wet and buttons dont work
open the fone and carefully isolate the board from the battery and the keypad. dry all components and re=pack them. be careful not to spoil the mouthpiece
Jul 17, 2010 | Motorola Mobility Karma QA1 Cell Phone
I have a motorola karma the back button wont work if my cell is open but it works when its closed also the down button doesnt work.and now the a button doesnt work either ? ive only had it for about 3...
So the phone I have is the motorola hint, QA30, actually identical in design (except square, red and black) and I have similar problems, my right navigator (right shoulder) and my up and left buttons, as well as my send button, will randomly stop working, I find (in all seriousness, no joke) that sometimes hitting the phone (lightly of course) seems to get the buttons to work again,
Jun 17, 2010 | Motorola Mobility Karma QA1 Cell Phone
My phone dect 6.0 uniden rings when someone calls but will not dial out
Hello :
Maybe you need to program the phone .
Here I'll tell you how :
  1. Press the Down main navigation button and press Menu/OK. The main navigation button is in the center of the keypad and is cylindrical in shape.
  2. Press either the Up or Down main navigation button until "New Entry" appears on the display.
  3. Press the Menu/OK button and "Enter Name" will appear on the display.
  4. Enter the name using the keypad. Enter the names the same way you would enter text in a text message on a mobile phone. For example, to enter the character "H," press the 4 digit twice. Use the labeling on the buttons to guide you.
  5. Press the Menu/OK button after entering the name and "Enter Number" will appear on the display. Enter the phone number using the keypad.
  6. Press the Up or Down navigation button to select "Save" or "Go Back" and then press Menu/OK. The entry is now programmed. Press the goodbye button; it's the button with the phone icon on a cradle.
  7. Press the Down navigation button and the first alphabetical number is displayed. If you keep holding the button, the phone will scroll through your phone book alphabetically.
  8. Press the button with the phone icon on it (not the goodbye button) to dial the number associated with the phone book entry.
I hope that will help .
rate if useful please !
Feb 22, 2010 | Uniden DECT 6.0 Cordless Telephone...
Retrieve files from sony 525a with blank screen?
to retrieve your numbers you would need to follow these key strokes...
center, toggle down (1 time), center, toggle up (2 times), center, toggle down (5 times), center, toggle down (5 times), center (3 times)
then wait for quite some time...it takes a while to copy all of the contacts...I would say anywhere from 5 to 10 mins...
this should work to save your contacts.
To save your pictures (and any other data you might want to retrieve) you could buy Sony's data cable2.gif for the z525a. I haven't tried this but it should work since that is what the cable is for.
Its called a DCU-60 USB data cable, and is listed as being compatible with the z525a.
to turn on the bluetooth: center, toggle down (2 times), toggle left (1 time), center, toggle left (4 times), center (2 times). then the return button 3 times to go back to the "main screen". hope this helps
Dec 20, 2007 | Sony Ericsson Z525a Cellular Phone
Motorola Mobility Karma QA1 Cell Phone Logo
279 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
