I have a Philips Cineos Mod# 44PL9523/17, my picture is getting dark, I'm not sure when this started. About two months ago the Lamp Warning Light came on, so I replaced the bulb, this did not help. The screen is even darker around the edges. The TV still has a good picture, but I have to get it as dark as I can in the room to watch it comfortably, It started this about a year ago, could it be I have the wrong bulb or do you think I have a more serious problem? Thanks
    President:
  • 1,462 Answers
HI,
There also seem to be a capacitor(it is the 33 uf/160 volt cap) in the high voltage line which after replacement may lighten up your set...
Remove the back panel of your TV, on the D board you'll find an electrolytic capacitor. If you don't easily see the D stamp on the board you'll know you're on the right board when you're in the 500 series position numbers. On the cap will be the markings 33uf/160v and it's polorized so there is a positive and negative. The new cap has to be placed in the circuit according to its polorized direction and the cap indicates which side is negative... You can easily other see caps on the board and what denotes their negative side with relation to the direction on the board. Usually, the negative side marking on the board will have a small box or block near the hole opening denoting negative
A single cap like that can be purchased from your local electronic supply store. Just tell them you want a radial 33 micro ferret 160 volt electrolytic capacitor. Should be about 3-4 dollars... If you try and buy these from a wholesale distributor you'll get a better price but usually you have buy minimums to contend with..Chenaging this capacitor would solve your issue...
Please leave me comment, if you need further assistance
Thanks for using FixYa!
Rnj VINODKUMAR
Posted on Nov 16, 2009
SONY WEGA KDF-50WE655 PICTURE IS DARK MY LAMP IS ONLY 2 MONTHS OLD
Where did you buy your lamp? sounds like its not a real philips or osram. Discount merchants sells some junk lamps. If you got it there, thats your problem
Jun 13, 2016 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a mitsubishi WD- 6oc9 tv when i power my TV i get a steady blinking light and no picture. my husband replaced the lamp about six months ago. dont think thats the issue. need ideas on how to repair.
Sounds like lamp needs replaced. If you purchased a cheap lamp from ebay or your installer did, that is about all they will last. On your next lamp buy an osram or Philips lamp. They are a lot better quality.
Feb 05, 2014 | Mitsubishi Televison & Video
Power light glows orange for a minute then shuts down without ever having a picture or sound. I have replaced the lamp and clean the filters. This is a Philips Cineos Lcos 62 inch.
Watch at turn on to see if lamp fires up for even a second or two--if not either a ballast or the control that turns it on has detected another issue and is not allowing the lamp to come on.
Jun 07, 2012 | Televison & Video
I have a Philips Cineos 55" 55pl9773/17 that has an issue with the picture where it is dark around the border or edges of the screen. Basically, to put it differently, the outside of the screen is...
open up the back of the tv and look to see if any of the capacitors on the power supply or video board are swollen or oozing out stuff....if so replace them and should work
May 04, 2011 | Televison & Video
Ihave a Philips 50PL9126D tv and I just replaced the lamp because the picture was very dark. I can see the picture but it is still somewhat dark, bright in the middle,dark at the edges. I tried to adjust...
Sounds like you may have the wrong lamp. Make sure you purchased a Philips lamp that's 100% compatible with your television model. Philips pioneered that lamp, so naturally they make 100 different types for DLPs and LCD projections.
You may have an elliptical lamp instead of parabolic. The lamp for your TV should read P22h.
Feb 04, 2010 | Philips Televison & Video
Blue screen
I would suggest getting another optical block from the repair man. Apparently even some replacement blocks have had issues...
Jun 06, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Zenith HD 44 inchr red lamp light is on
sir,,,maybe,,,,,but you said your tv is ok soo i think its just alright,,,thnkss
Jan 29, 2008 | Zenith E44W46LCD 44" Rear Projection...
Dark Picture
If the Lamp condition is okay then check the FE lens just next to the lamp in the projector after removing the lamp out of prj. replace if that is burnt.otherwise replace Lamp.
Viren
Nov 13, 2006 | NEC VT460 Multimedia Projector
Televison & Video Logo
Top Televison & Video Experts
