Question about HP Officejet 7130 All-In-One InkJet Printer
Cannot fax out, hear diall tone however ,always number busy
    Guru:
  • 1,738 Answers
Try a different fax number, it just could be that number is busy and keep trying.
Posted on Nov 16, 2009
Why won't the fax work?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Skelton Business Equipment Houston Copiers
May 08, 2014 | Sharp MX2610N Printer
On 6-4-2012 could send fax, now 6-07-2012 can't send or recievsed fax
Please check the settings on the fax machine. check the line to the fax and also the connectors, check using a phone to hear the dial tone.
If this seems good check if the fax dials the call, if not check the settings for pulse or tone and reset. If there is not dialling then the fax machine has problems that are serious which might need careful probing.
Jun 06, 2012 | Brother MFC 420CN All-In-One InkJet...
I am trying to fax, but I keep getting a "busy"
Make sure you have pluuged the telephone line lead into the "LINE" socket and not the "TEL" socket of the fax machine. I reckon thats why you are not dialling out correctly. If this is in an office, make sure you are dialling the access number for an outside line, usually a 9 before the phone number.
Jul 19, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
There is a fax tone when dialling our telephone number.
Set your fax to MANUAL MODE. You will have to press START when you know you are getting a fax.
This is the only way it will work without a dedicated fax line.
Nov 30, 2009 | Canon FAX-JX200
UNABLE TO SEND OR RECEIVE FAXES WHEN DIALLING OUT ALWAYS GET ENGAGED TONE
Check whether it is dialling 9 first (or whether it needs to dial 9 first)
Nov 18, 2009 | Brother MFC 240C All-In-One InkJet Printer
What is error code 634
Error Code 634 indicates a call that was placed did not go through:
"Redial was not successful due to no response from
the called station or wrong number dialled.
Note: If busy tone was not detected, the machine will
only redial once
Sep 03, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Status 50 on a fax estudio 45
the number is busy. Try pressing the monitor button and listening for a dial tone. No dial tone means your phone line is not working. If you have dial tone, dial the number you wish to fax and listen to see if it picks up. If you get a busy signal, or hear someone answer, that is why it's not working. If you hear the fax tones, press start and send your document. This is a way to fax that allows you to hear the whole process.
Aug 10, 2009 | Toshiba E-STUDIO 450 Copier
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
Fax nightmare!!!
If you have a BT line and use the 1571 answering facility , when you have a message waiting the dialling tone changes from a constant tone to a split tone. This is to let you know that you have one or more messages waiting.
In order to get the dialling tone to revert to the constant tone you have to deal with the waiting messages in accordance with the options provided i.e Save, Listen Again or Delete. BT say the Split Tone is to let subscribers know when they have a message waiting. This should resolve the Fax problem.
It certainly worked for my phone/fax system.
Good Luck
Geowilmil
Nov 28, 2007 | Pitney Bowes 9920 Plain Paper Fax
HP Officejet 7130 All-In-One InkJet Printer Logo
95 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
