Question about Cell Phones
My screen rarely works anymore. I have no idea how to fix this.Is there anyway to fix fix this?
Highlander DVD player has line down screen
I am not familiar with this but I presume you refer to a portable type car unit which I see on the web.
Is this line a twinkle type line or a clean dark line?
Both will tend to be a player fault which may not be able to be fixed (in todays chuck it out world).
If its a solid clean dark line then this may be a display screen fault which laptops etc can get, the only cure change its display panel (often pricey so not worth it)
Then again if this a twinkle white type line, to me this a component failure (capacitor) which there many inside whose job is to remove noises. A service is required if possible with that company (could be costly if an older unit) or sadly "live with it" as it mostly will only spoil enjoyment rather than create a serious issue.
It can be on a disc but I presume you have tried others anyway (rare anyway, except if you record your own discs then it can be your recorder putting it on) again rare.
Hope this helps................
Jun 04, 2016 | Televison & Video
Vertical line complant
This is not the vertical line complaint. It is vertical retrace line on screen problem. Might be and IC fault [main chroma] or improper screen voltage. In rare cases this might be of a faulty video output transistor. Anyway, vertical retrace lines are visible on screen, is the problem. If you wish to get more details abut this, just visit the site linked here. Type in " My service table today" as key phrase, in the search box; can be located at the top right of the display window. You'll get an idea about how to proceed.
Look into all gathered posts.
Jun 19, 2015 | Televison & Video
I have a 820S kenwood I purchased it from a pawn shop in California, I could not get the S meter to sense the incoming signal / I played with the connectors and the S meter started working. Well it quit...
What is your ham radio call sign? I rarely look at the s-meter. If you can hear the other station, you probably can work them. The s-meter is valuable when turning your directional antenna to locate the transmitting station better. If your antenna won't turn, call him anyway.
Jul 08, 2014 | Radio Communications
Need to know how to install or repair air conditioner clutch on 2003 jeep liberty renegade.
I would recommend changing the whole compressor,rarely do I replace clutches anymore to much time and trouble and most likely the compressor is worn out anyway,but if you want to tackle it you will need a clutch tool to remove and install and you will need shims.
TIM.............
Oct 24, 2010 | Jeep Liberty Cars & Trucks
I have a 98 cherokee and the driver door doesnt lock with the remote or with the panel switch- although i can hear the motor whizzing. it will however lock manually. also, it SOMETIMES(although very...
the lock motor could be jammed or a gear inside it could be broken. best bet would be to go to a parts store or junk yard and get a new one and try that out.
Feb 23, 2010 | 1998 Jeep Cherokee
We have lost a two inch wide black section on the right side of the plasma panel, any ideas
Most likely the lower buffer board " E " needs to be replaced. Right now I'm working on repairing a 42" Samsung plasma HP-R4272. The Service manual for that TV says for trouble shooting for that problem is the lower buffer board " E ".
Best to find the correct Service Manual for your TV over the internet to get the correct part number for replacement. The Service Manual should be less than $20.
Oct 25, 2009 | Samsung PS42P2S 42 in. Plasma Television
Ds red light flashes briefly
Is your DS old? If your battery is charged 500 times, it won't work anymore says Nintendo. Anyway, get it fixed by Nintendo!
Oct 09, 2009 | Nintendo DS Console
My polti vaporetto 2400, I can't open the lead
you need to remove the top anyway you can and replace with new
May 05, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Inkblot on my screen
The display is leaking. Nothing to do but get it replaced/fixed , or purchase a new piece, as I do not think Sansa sells spare LCd's..
May 13, 2008 | SanDisk Sansa e270 MP3 Player
My iphone fell
You can't really do anything from your standpoint, I'm sure that apple doesn't just replace the screens, but have you tried to call them at all? Other then that you will need to buy a new one.
Apr 20, 2008 | Apple iPhone Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
