Question about Sony KP-53XBR45 53" Rear Projection Television
I have a Sony kp53xbr35 rp tv, the problem is that i turn it on the lights begin to turn on. the screen turns blue to blue green then red and the tv shuts off. i can still get sound but no picture. the timer/stand by light light blinks 12 times does any one know the code for the twelve lights. also recently the convergance was all messed up it bowed in the middle and the colors would not line up. i know the convergance ics need replaced but would that make the tv power off? does any one know how to fix thanks.
  • Sony Master
  • 3,459 Answers
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
i have a Sony kp53xbr35 rp tv, the problem is that - bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 06, 2010
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
The screen turns blue after about 2 minutes of turning on the TV
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 25, 2010 | Sony KP-57HW40 57" Rear Projection...
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
I have a Sony kp53xbr35 rp tv, shutting off
If you know that the convegance IC are bad then I would replaece them frist and see if that will fix the whole problem, it just might. Here is a sight you can go to that may help you if that does not fix it www.somelifeblog.com has some good info on sony not your model but could be same problem. check it out and see.
Nov 16, 2009 | Sony Televison & Video
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
Hi toshiba 43 rp
You have a confusing mixture of data......Please provide
Make,model,age and chassis off sticker on back of set.....T.
Nov 26, 2007 | Toshiba 53H71 53 in. Rear Projection...
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
Blue Screen
Your blue crt has a short - you can verify this by unplugging the socket from the blue crt and powering up the set and you should see a yellowish looking picture with just the red and green crt's operating. You can try turning down the screen control pot (B) for blue with the blue crt on (just to the point where you no longer see retrace lines in the picture on a blank input)Sony has had a lot of problems with the crt's on these models and sooner or later all the crt's will fail - For a permanent repair all must be changed.
Aug 20, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
145 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
