Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
I have a kenmore range the oven burner does not work but the broiler does. The igniter on the oven element appears to glow in preparation of lighting but propane does not come out of the element. Now when i installed the range i converted the stove top burners as instructed. I didn't do anything to the regulator because the mounting of the regulator and dont recall the manual instructing too. I wonder if the problem is with the regulator or valve? the Model of kenmore range is 790.75711893 Thanks for your time
  • Kenmore Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
sgf
Posted on Sep 30, 2010
Neither the oven nor the broiler burners will light. In both cases, the igniter glows, but no gas to the burner.
UNLESS DOUBLE OVEN THE BROILER BURNER HEATS THE OVEN. AND THERE WOULD ONLY BE ONE IGNITER. WHICH IS PROBABLY DEFECTIVE AS THAT IS A COMMON PROBLEM WHEN USING IGNITER.
Mar 10, 2010 | Maytag MGR5750 Gas Kitchen Range
I have no heat coming from the oven portion of my kenmore 790 electric range after hearing a "pop" sound. fyi, the element looks intact.
Top burners are working, broiler is working, bottom oven burners dont ignite and dont heat the oven? What can we do?
Dec 30, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Broiler does not work!
rEPLACE BROILER ELEMENT. LOOK INSIDE OVEN, FIND SCREWS ATTACHING ELEMENT TO BACK PANEL. TURN OFF POWER. REMOVE SCREWS, SLIP OFF WIRES.
Oct 21, 2009 | Kitchen Ranges
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Amana broiler problem
Each burner manifold in the oven has its own igniter. If the igniter is defective, the burner assembly will not light. The igniter has to be functioning properly in order for the gas safety valve to open. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. This reduces the risk of explosions.
There should be a flame spreader metal plate covering the access over the broiler. You will need to access the broiler so you can view the broiler manifold and igniter. Turn the oven setting to broil and make sure the igniter begins to glow. If the igniter fails to glow, replace it. If the igniter does glow, but you still do not have ignition after 90 seconds, the igniter may be weak and still require replacement. The following link explains oven igniter types, their current potential, and how to replace them:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Amana RanARG7302 Gas Kitchen Range
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Burners & Broil work but Oven burner does not!
HI thanks for your question. the problem is with the bake igniter. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven will not work,burners and broiler all work fine
under the floor of the oven, possibly can be see by removing the bottom drawer. the ignitor is hte most common aprt to go bad in any gas oven, visually it might not even look broken though and some even appear to glow(just not strong enough to open gas valve
Mar 01, 2008 | Kenmore 78570 / 78571 / 78572 / 78574 /...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
352 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
