Question about Garmin nuvi 1350 Car GPS Receiver
My Garmin 1350 went black while plugged into the car power source and will not turn back on, with or without being connected
This work for me:
maintain the power button pushed while connecting the cable.
good luck
Posted on Nov 16, 2009
It is working ok but the screen is too bright, without adjust Is it a hardware or software problem? thanks
You should be able to adjust it using Tools - Brightness. If you can't it is more likely a software glitch, as long as all the other touch controls on the screen work.
You can update the software here.
http://www8.garmin.com/support/collection.jsp?product=010-00782-20
You can also do two types of reset.
How to Reset a Garmin 1350 by Kefa Olang, Demand Media Whether you're on a local or national business trip, a Garmin Nuvi 1350 GPS can help you find your way around. However, if the device is not functioning as expected, performing a reset is a troubleshooting step that can solve common problems. A soft reset reboots the GPS's hardware without deleting saved data, but a master reset clears saved data and settings to restore the device to the factory state.
Step 1 Press and hold the "Power" button for a few seconds to reset your Garmin Nuvi 1350 if it's not performing as expected. This soft reset reboots the device's hardware without deleting saved files.
Step 2 Turn off the Garmin Nuvi 1350 if you're still experiencing problems, and then disconnect it from a power outlet, if it's connected to one.
Step 2
Touch and hold the lower-right corner of the screen while powering on the device. Release the power button when the screen turns on, but keep pressing down on the screen. Step 4 Touch "Yes" when the "Do you really want to erase all user data?" message appears on the screen. If the text is in another language other than English, touch the button on the right to confirm your selection.
Step 5 Wait for the GPS to reset automatically, and then follow the on-screen guided prompts to reconfigure it.
Jan 15, 2016 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Would you like to back up a copy of your Garmin Nuvi 1350 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
______________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Hard Reset
on May 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
I cant power up my Garmin Nuvi 1350
One possibility is a loose or broken mini-USB jack. This would prevent any external power source from turning on the unit and charging the battery. This is a common problem with this model. please see this link for more info:
http://www.sharc.net/gps_charger_repair.htm
Apr 07, 2013 | Garmin nuvi 1300 Car GPS Receiver
I have a garmin 1350 t have had for 6 months..just went black while traveling..took it back to WM..they said to send to garmin
The nuvi 13xx 14xx series had problems with the firmware bricking the unit, if you are unable to connect to the PC and update the firmware with Garmins WebUpdater it will have to be sent out for warranty.
Hope this helps!
Dec 08, 2010 | Garmin 1350T GPS Receiver
When I plug the power cord for my Garmin into the car, the display instantly is too dark to see anything. When the cord is removed and the Garmin is running on battery, the screen is fine. Shouldn't be...
Without knowing what model Garmin you have, perhaps there is a "night mode" illumination display option available and has been selected.
Sorry this is vague, but I hope it is of some benefit to you.
May 02, 2010 | Garmin nuvi 1350 Car GPS Receiver
My Garmin GPS 1350 will not turn on even when plugged
Ramdomly my Garim 1350 GPS does not run on when plugged into car charger
Mar 28, 2010 | Garmin nuvi 1350 Car GPS Receiver
My Garmin 1350 is fully charged. I used it
the software on garmin 1300 models is atleast 3.6/7 sounds like ur update didnt take, also check in settings see if you have a timer setting for sleep mode/stanby after x time
Dec 26, 2009 | Garmin nuvi 1350 Car GPS Receiver
When plugged into the car power source my Garmin Nuvi 1350 screen turns black, but I can still hear the audio. When I unplug the power source the screen comes back.
HAVE YOU THE GARMIN POWER LEAD? IF NOT IT MAY BE THE FAULT, IF YOU HAVE THEN IT STILL MIGHT BE DEFECTIVE, TRY AND SOURCE A NEW LEAD OR CONNECT TO PC WITH MINI USB SEE IF THAT MAKE A DIFFERENCE, IF NOT THEN DEFECT IN UNIT, TRY SOFT WARE UPDATE FROM WWW.GARMIN.COM
Dec 15, 2009 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 1350 Car GPS Receiver Logo
509 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
