Question about LG RUMOR Cellular Phone
My rumor two shuts on and off continuously - like the end button is being held down. a red light in the upper right corner lights up prior to it shuting down.
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
I want to change current keypad code linear LD050 model
To change the keypad code.
Step 1:
Erase the current code - On the upper right hand corner of the left hand side of the unit, you will see a "learn" button.
Press and hold the "learn" button for 12 seconds.
When you release the learn button, the red light above the button will blink 3 times and then come on bright for 15 seconds.
When the light goes out, the memory in the operator is erased.
Step 2:
Learn a new keypad code.
Press and release the "learn" button.
The red light will come on. You now have 15 seconds to complete the next task.
Go to your keypad and enter your desired code (1 to 6 digits long)
press start/stop on the keypad.
The red light will blink when the code is successfully stored.
Don't forget to re-enter all of your hand held remotes into the memory:
Press and release the learn button. When the red light comes on, press the button on the remote you wish to update.
Repeat for other remotes. By the way, If you hold the learn button down for 10 seconds, you'll have to start over and the memory will be erased.
Nov 14, 2012 | Home Security
Flashing red power light on Gateway 700X
try disconnecting the lower optical drive and rebooting...may just be a bad drive.
Sep 04, 2012 | Gateway 700 X PC Desktop
How to set up garage door opener on my 2002 diamante
Detail Instructions from the owner's manual 1. Turn off engine
2. Prepare transmitter by erasing all three of the factory default channels by holding down the two outside buttons until the red light begins to flash. Release both buttons.
3. Hold the end of your hand-held transmitter (garage door remote) against the Homelink transmitter keeping the red light within the Homelink icon in view.
4. Using both hands push the hand-held transmitter button and the deisre button to be programmed on the Homelink transmitter. Do not release the buttons at this time.
5. Hold down both buttons until the red light on the universal transmitter flashes, first slowly then rapidly. When the light flashes rapidly, release both buttons.
To program the remaining two buttons, follow steps 3-5.
Jan 17, 2010 | 2002 Mitsubishi Diamante
Red Light Indicator Flashing??
There is an old message stuck in memory. Hold down the OFF button on the base handset for 10 seconds.
Dec 02, 2009 | Uniden DECT 6.0 Cordless Phone ID
Uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
Feb 07, 2008 | Uniden Cordless Phone
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
LG RUMOR Cellular Phone Logo
111 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
