Question about Epson Stylus NX400 InkJet Printer
Windows will not let me install my nx410 - Epson Stylus NX400 InkJet Printer
    President:
  • Epson Master
  • 2,017 Answers
In run window type services.msc and then go to windows installer and start the service and set it to auotmatic and restart the computer and try for installation also see the user rights log on with administrator account if you have more then one user.
Posted on Nov 16, 2009
2 Suggested Answers
tech-agent
  • 83 Answers
SOURCE: We are trying to install an Epson NX410 on a HP
hi there..
if you are downloading the combo package driver, and your having an issue. thats normal. combo package driver of epson usually have issues, so they suggest to download the driver separately. since you already download the scanner, download the driver and make sure that you select the right driver, because there are 2 types of windows 7, 32bit and 64 bit, if you are downloading 32 and you have 64, it wont work and vice versa, so double check.
download the driver from this link according to your os.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=128287&prodoid=63083741&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=26&y=10
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Posted on Feb 20, 2010
How to change ink cartridge in epson nx215
1. Turn on your Epson printer. 2. If a cartridge is expended, you see a message on the printer's LCD display screen. The icon on the screen indicates which color to replace. Press ink.13.7.1.jpg Start (NX210 Series) or OK (NX410 Series). If you're replacing a cartridge before you see a message on the printer's LCD display screen, do one of the following: NX210 Series: Hold down the Scan button as you press the Index Sheet button, then release the buttons. Press ink.13.7.2.jpg or ink.13.7.3.jpg to select Ink Cartridge Replacement, then press ink.13.7.4.jpg Start. NX410 Series: Press Setup, press ink.13.7.5.jpg or ink.13.7.6.jpg to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 3. Open the scanner. Note:
Your printer model may vary from the ones shown in this section, but the procedures are the same. ink.13.7.7.jpg Note:
Do not touch the white cable inside your printer.
Do not open the ink cartridge cover while the print head is moving. ink.13.7.8.jpg 4. Open the cartridge cover. ink.13.7.9.jpg 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. ink.13.7.10.jpg Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) ink.13.7.11.jpg 7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. ink.13.7.12.jpg 8. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. ink.13.7.13.jpg 9. Insert the new cartridge into the holder and push it down until it clicks into place. ink.13.7.14.jpg 10. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. ink.13.7.15.jpg 11. Lower the scanner. ink.13.7.16.jpg 12. Press ink.13.7.17.jpg Start (NX210 Series) or OK (NX410 Series) to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. If you continue to see an ink replacement message on the LCD display screen, Press ink.13.7.18.jpg Start (NX210 Series) or OK (NX410 Series) and press down all the cartridges securely. Then press ink.13.7.19.jpg Start (NX210 Series) or OK (NX410 Series) again. Note:
If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. Caution:
Never turn off your Epson printer while ink is charging or you'll waste ink.
(Taken from the Epson online manual available here)
Oct 16, 2012 | Epson Stylus Multifunction Inkjet Printer/...
EPSON STYLUS nx410 PRINTER NOT RECOGNIXED BY MICROSOFT LOGO
Look for CD that came with printer to install drivers on your computer. If that is not available, you can search the internet for printer drivers for your specific printer. Make sure your computer has all it's current Microsoft updates too (many times newer printer drivers don't get added to the updates right away).
Apr 29, 2012 | Epson Stylus NX400 InkJet Printer
NX415 inkjet catridge refill
This is what I found on the Web. You can download the Manual if you like. Click on link below. Not able to put all here, do to limitation.
http://files.support.epson.com/htmldocs/nx415_/nx415_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Remove and Install Cartridges
Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones.Caution: not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1.
2.
If a cartridge is expended, you see a message on the printer’s LCD display screen. The icon on the screen indicates which color to replace. Press or OK (NX410 Series).
If you’re replacing a cartridge before you see a message on the printer’s LCD display screen, do one of the following:
to select Ink Cartridge Replacement, then press Start.
NX410 Series: Press Setup, press or to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
Apr 04, 2010 | Epson Stylus NX400 InkJet Printer
Scan without replacing print cartridges on Epson Stylus NX410?
You actually can scan documents when you dont have ink. Instead you will have to activate the scan function from the epson driver/program instead of pressing the scan button directly on the printer. I had the same problem and it took a while to figure out.
Feb 19, 2010 | Epson Office Equipment & Supplies
Epson Stylus NX410 won't print in Adobe Illustrator CS
Try to print your file in jpeg or tiff format.Good luck!
Jan 12, 2010 | Epson Office Equipment & Supplies
I cannot get my epson stylus nx410 CD to load my driver. Went to epson centre no listing for printer
Epson does not make a NX410, They only make a NX400 and NX415.
Check the back of the printer for the exact model number. If when you check you it is for some strange reason it is a NX410. I would try one of the drivers from the NX4000 or NX415 as drivers for printers typically don't vary too much between similar models and may provide a good temporary fix to your problem.
You can also call epson US (562) 276-4382 6am to 6pm PST mon-fri
Driver link to NX400
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=106004&prodoid=63075469
Driver link to NX415
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=128287&prodoid=63083741
Jan 08, 2010 | Epson Stylus NX400 InkJet Printer
We are trying to install an Epson NX410 on a HP dv6-1362 running Windows 7 Home addition but can not get it to install. The HP will only see the scanner. We could install the Epson NX410 on a white box...
hi there..
Dec 08, 2009 | Epson Stylus NX400 InkJet Printer
I cannot get my epson stylus nx410 CD to load on my computer
hi there this is the set of instruction on how you can install the cd on your computer
http://files.support.epson.com/pdf/nx410_/nx410_bb.pdf
hope this 1 will help
Nov 28, 2009 | Epson Stylus NX400 InkJet Printer
I was setting up my EPSON styus NX410 series and plugged it into my computer before setting up.How do i fix it?
Very simple fix....
Unplug the printer. Install software, plug in printer, restart computer, it should "see" the printer and click on the icon and do a "test print"....make sure your printer is plugged into both the wall and the computer. If you need to, update your drivers also.
Sep 16, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
173 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
